tranny question
#787182
02/07/07 04:40 AM
I have been told yes and no so i figured i would ask, does anyone know if a tranny that came out of a 4.0 will bolt up to my 93 4 cyl.? If not is there any way that my bell housing will bolt up to this tranny?
01 Tacoma 3 inch suspension, 3 inch body 35's 94 wrangler 5.5 inch springs, 4 inch body 37's
Re: tranny question
[Re: jeeyguy310]
#787183
02/08/07 12:57 AM
Which trannys? Which year 4.0? <img src="/forums/images/graemlins/confused.gif" alt="" /> It doesn't matter, the answer to both Q's is no. <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: tranny question
[Re: JeePete]
#787184
02/08/07 01:38 AM
are there any other tranny's that will bolt up to my 4 cyl. other than the stock one? I have been through 4 of the stock tranny's and they r the worst tranny's ive ever seen, so I was looking for something I could try instead, but I want it to be a standard, no auto's.
Re: tranny question
[Re: jeeyguy310]
#787185
02/08/07 02:06 AM
your best bet is to check out advanc adapters and see what they may have for that engine to adapt a different tranny to.
Re: tranny question
[Re: jeeyguy310]
#787186
02/10/07 02:17 AM
I know there are other options but can't tell you what they are off hand. I believe the bell housing bolt pattern is a GM design. The AX-5 (what I guess you have) bell housing is good for nothing else as far as I know. Sorry I can't say more, Calling the Adapter people (Novak or Advance Adapters) might be a good idea, They might suggest more than one alternative. Good luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6037 MB (Peak: 0.6675 MB) Data Comp: Off Server Time: 2026-05-29 18:37:57 UTCValid HTML 5 and Valid CSS
