Re: double filters [Re: OOP'S] #787224 02/09/07 05:12 AM
cktoy Offline OP
so who said I had a hood? <img src="/forums/images/graemlins/nana.gif" alt="" />
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: double filters [Re: cktoy] #787225 02/09/07 05:16 AM
OOP'S Offline
Guess I should have figured that since you are from Tennessee!!!!!!!!!!!!!!!!!!!!!!!!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: double filters [Re: OOP'S] #787226 02/09/07 04:35 PM
cktoy Offline OP
I dunt git it? <img src="/forums/images/graemlins/notooth.gif" alt="" />
oh what a feeling:
84 supra yard art
Re: double filters [Re: RatLabGuy] #787227 02/09/07 04:42 PM
cktoy Offline OP
[Assuming you've upgraded other things so you can use it] I have ,cam header exhaust,I have a strong little weak engine <img src="/forums/images/graemlins/lol.gif" alt="" />
oh what a feeling:
84 supra yard art
Re: double filters [Re: cktoy] #787228 02/09/07 07:05 PM
RatLabGuy Offline
I don't get it
Then, you *should* be able to get *something* (if not much) out of this.
The idea behind it is, more air in = more explosion = more power.
However, you can only "pull" air in as fast as you "push" it out. The activity of the engine is what's the creating the vacuum. Generally speaking, the 22re is fairly balanced on this already in stock form. So, if you were to JUST open the intake, it will not really suck in much more air b/c it is still limited by how fast it can get out on the other end. However, by opening the back end more, it changes the equation, and you can now get more IN. Changing cam profile helps this too.
As Oops has pointed out, you will only benefit when the amount of air coming IN is about the same as going OUT. Colder air is more dense, more air per unit volume, so it works better for this than warmer air.
Re: double filters [Re: RatLabGuy] #787229 02/10/07 07:27 AM
cktoy Offline OP
thanks , right now it seems to be good,I may have to change it back this summer,but there is plenty of cold air right now around here.
would cooling my fuel have the same effect ( more btu per unit of volume) and help any .
I,m thinking of adding an electric fan under the hood in addition to my stock belt drive fan this summer to help with the heat from the header.
oh what a feeling:
84 supra yard art
Re: double filters [Re: cktoy] #787230 02/10/07 03:10 PM
Adam F Offline
Smarter thing to do would be to remove the mech fan, add a electric fan, and use some header wrap.
97 4R, stock, daily driver
Re: double filters [Re: cktoy] #787231 02/10/07 03:46 PM
OOP'S Offline
would cooling my fuel have the same effect ( more btu per unit of volume) and help any.
In my drag racing days, we built a canister that hooked into the fuel line that had a coiled line in it that we could pack with ice for that very reason. This was a standard practice in those days (the 60Æs). Header wrap will also help with under hood heat.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6289 MB (Peak: 0.7286 MB) Data Comp: Off Server Time: 2026-06-20 15:29:51 UTC
