Page 2 of 4 1 2 3 4
Re: I am running 37s now [Re: Scottie2113] #787445 02/08/07 03:30 AM
DavidG Offline
That is sweet!
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
Re: I am running 37s now [Re: DavidG] #787446 02/08/07 03:53 AM
sparkem Offline
Badd <img src="/forums/images/graemlins/butwiggle.gif" alt="" />. Solid axle in 10, 9, 8, 7, 6.......
Awesome.
Re: I am running 37s now [Re: sparkem] #787447 02/08/07 05:28 AM
DougH Offline
Mitsubishi Forum Moderator
Three inches on top of the stock SR lift? So you are running four inches compared to a stock genII from say 1993?
DougH
1995 SR - RIP
1993 RS - RIP
Re: I am running 37s now [Re: sparkem] #787448 02/08/07 05:58 AM
LandRaider Offline
[quoteSolid axle in 10, 9, 8, 7, 6.......[/quote]
5, 4, ......... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I am running 37s now [Re: cap510] #787449 02/08/07 06:29 AM
Angelo Offline
I hope everything works out for ya. Thats def pushing the SR to the limits. What about any testing. Flex it to the limit, does it rub? Honestly, I think 35's are the biggest i'll be going. It might be able to handle it, but you'll be replacing steering parts sooner than normal.. I would go for a SAS, any future plans for that? Or should I say, how soon before a SAS? <img src="/forums/images/graemlins/kewl.gif" alt="" /> Keep up the good work. You've always been the first to do alot of things on Monteros, good luck
Re: I am running 37s now [Re: sparkem] #787450 02/08/07 08:27 AM
cap510 Offline OP
Awesome.
Yeah, I have a SAS backup plan already <img src="/forums/images/graemlins/wink.gif" alt="" /> but honestly I would like to keep it MITSU as much as possible. Nothing wrong with other brands but it's just cool to have such a beast with only Mitsu parts and a few mods. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I am planing on hitting the trails the following weekend to stretch the suspension and see how well it holds up! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: I am running 37s now [Re: cap510] #787451 02/08/07 01:11 PM
Damn,
Now between you and Scottie you are making me want to do this with my SR.
Mine is intended for towing a trailer with casual trail use.
Maybe I will do another Gen 1 SWB with 35s.
I will be making a torque arm setup for the coil spring rear to eliminate binding back there. This is a few months away but I think it will be a good thing.
Re: I am running 37s now [Re: OldColt] #787452 02/08/07 02:00 PM
Scottie2113 Offline
yeah, except I don't think I will ever go bigger than the 35's I have now, but of course, I said that when I had 32's on my LS. One more thing to think about, once I start using my arb in the front axle, I will have to use caution b/c with 35's and a front locker, you could really snap those CV's in the front. carlos, are you running a front locker with those 37's, or would that be the SAS plan you have?
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: I am running 37s now [Re: Scottie2113] #787453 02/08/07 02:33 PM
icysyrup Offline
Looks good. I am curious to see how well it holds up to wheeling when you run it. I am sure it will take a smarter approach to certain parts on the trail but thats fine as long as the right person is behind the wheel. I like the idea of keeping everything as Mitsu as possible.....makes it more "authentic".....Keep us posted on how it holds up...and kudos for being the first pioneer to try it.... <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: I am running 37s now [Re: OldColt] #787454 02/08/07 03:50 PM
funny i'm doing a torque arm setup and removing the rear trailing arm bolt for some extra flex
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6480 MB (Peak: 0.7532 MB) Data Comp: Off Server Time: 2026-06-17 12:56:40 UTC
