Page 3 of 4 1 2 3 4
Re: I am running 37s now [Re: TOASTY] #787455 02/08/07 04:37 PM
powerRam50 Offline
i am pretty sure i could stuff 37's.
Re: I am running 37s now [Re: TOASTY] #787456 02/08/07 04:40 PM
Tag Offline
Quote:
I will be making a torque arm setup for the coil spring rear to eliminate binding back there.
funny i'm doing a torque arm setup and removing the rear trailing arm bolt for some extra flex
Can you guys please give more info on these mods you are talking about.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: I am running 37s now [Re: Tag] #787457 02/08/07 04:51 PM
Alex Kogan Offline
They are removing one of two bolts (rear one) from the bushing on control arm holding rear axle in place. this will decrease binding then one of the sides drop. Increasing flex. I personally wouldn't do it for safety reason. If due to increased stress remaining one brakes on hwy such as hitting pothole result would be disastrous. Flex will still be limited by bushing upfront.
Keep up the good work Carlos
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
08 PowerWagon (stock!)
Re: I am running 37s now [Re: cap510] #787458 02/08/07 05:47 PM
LRJ4x4 Offline
Those tires are huge <img src="/forums/images/graemlins/mrt.gif" alt="" /> Just waiting to see if the IFS can and tie rods can take it <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: I am running 37s now [Re: Alex Kogan] #787459 02/08/07 06:57 PM
No, What I am doing is adding a third arm in the center.
It will attach near the pumpkin and anchor up on the trans crossmember. This will take all the torque.
The outer arms will then anchor with a single point at the axle on each side. These will be my own fabricated parts,
I do not intend to rely on the factory arms.
With this method the suspension will be symmetrical and free twisting.
I will be making these parts for both coil setups as well a conversion for leaf springs.
I apologies for the thread jack. I was not ready to introduce these since they are still in Autocad, not in steel.
Re: I am running 37s now [Re: OldColt] #787460 02/08/07 07:14 PM
Alex Kogan Offline
That's cool. So it's basically custom 4 link or 5 link depending how you look at it. Are you going to use rod ends instead of rubber bushings?
Re: I am running 37s now [Re: Scottie2113] #787461 02/08/07 07:43 PM
cap510 Offline OP
carlos, are you running a front locker with those 37's, or would that be the SAS plan you have?
I already have a front locker installed, as a matter of fact I was the first one to installed an ARB front locker, 4.90s R&P, 3.15 TC, 35s on 15x10, 3" BL, 6" raised gas tank, trim rear quarter panels, etc, etc, on a genII here in the US <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
I just like to push the limits all the time, who knows what's next! <img src="/forums/images/graemlins/zombie.gif" alt="" /> (actually it's something pretty crazy but won't say much until it's done <img src="/forums/images/graemlins/wink.gif" alt="" />)
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: I am running 37s now [Re: Alex Kogan] #787462 02/08/07 08:01 PM
It will be a mix, the outer arms will be rod end on the front and rubber on the rear, this will allow some isolation for noise and comfort.
The torque arm will be hard mount to the axle and either sliding joint or rod link at the front. There is allot of movement at the front joint with this style.
I did not get any further when winter finally hit and I do not feel like laying under the rig.
Re: I am running 37s now [Re: cap510] #787463 02/08/07 08:54 PM
4xmonty Offline
[/quote]
I just like to push the limits all the time, who knows what's next! <img src="/forums/images/graemlins/zombie.gif" alt="" /> (actually it's something pretty crazy but won't say much until it's done <img src="/forums/images/graemlins/wink.gif" alt="" />) [/quote]
I am not worthy to be in your presence oh mighty one <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: I am running 37s now [Re: cap510] #787464 02/08/07 11:46 PM
Scottie2113 Offline
when you raised your gas tank, did you have to extend or modify any of the fuel lines or hoses or wiring harnesses, or did you just have to have brackets fabbed up and welded? Did you have to disconnect any lines or hoses from the tank, or did you just push it up higher and re-fasten it?
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6507 MB (Peak: 0.7585 MB) Data Comp: Off Server Time: 2026-06-17 10:31:05 UTC
