WHAT and WHERE IS the CRANKSHAFT SENSOR on a 97 sidekick? They say I need one to pass SMOG #787529 02/08/07 07:56 AM
hogair1 Offline OP
[color:"blue"] [/color]
Re: WHAT and WHERE IS the CRANKSHAFT SENSOR on a 97 sidekick? They say I need one to pass SMOG [Re: hogair1] #787530 02/10/07 09:40 PM
DesertTracker Offline
The Crankshaft Position Sensor (CKP) is used to sense the speed and position of the crankshaft for ignition timing control by the ECM. It is located on the front flange of the oil pan. It will have a two wire lead coming off it to a connector. For a quick check, the resitance between the two terminals of the connector should be 360-460 ohms. The CKP was only used on the 96-98 1.6L engines.
Ridgecrest, CA
2000 Tracker 2-dr
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 4.693s Queries: 15 (0.009s) Memory: 0.5865 MB (Peak: 0.6340 MB) Data Comp: Off Server Time: 2026-07-17 01:52:26 UTC
