Re: Oil pressure sending unit interchange?
#787570
02/12/07 02:03 AM
Thanks for the info. I ordered one as none of the local Kragens had it in stock. I'll advise if it works.
#787571
02/12/07 02:51 AM
Mine didn't have the ground terminal on it like the one pictured, but it still works the gauge fine.
'80 4X4 Longbed
[Re: Stevie]
#787572
02/12/07 07:33 AM
It looks like a ground terminal but I cannot see why there would be one since the sender screws into the block and gets it ground from there. I think it is because that sender is used on many different cars that have different style connectors. The connector on my 1988 was a dual style. It had a typical push on on the end and a slide on on the side. The push on was what was used for my old oil pressure switch. With the new sender I used the side of the connector and slid it on. ![[Linked Image]](http://usera.imagecave.com/ToolPants/Toyota/sendermycar2.JPG) ![[Linked Image]](http://usera.imagecave.com/ToolPants/IMG_2686.JPG)
#787573
02/14/07 09:59 PM
I have a 1988 22R pickup. I put in a 1987 4Runner 4 cylinder SR5 cluster in the pickup. It was a Yazaki cluster. I bought this sender from Kragens and the oil pressure gauge worked fine. Ok, I received and tried this sender today. Still no go. <img src="/forums/images/graemlins/frown.gif" alt="" /> When I ground the gauge, the needle rises to almost the top. I checked the resistance on the gauge and it checks out ok. Anybody have any ideas? I've tried three different senders now and the gauge still doesn't work. The tests I performed on the gauge are from the FSM and would seem to indicate it and the wiring to it are ok. TIA..
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6027 MB (Peak: 0.6604 MB) Data Comp: Off Server Time: 2026-11-17 11:01:12 UTCValid HTML 5 and Valid CSS
