700R-4 ????? #787748 02/09/07 12:19 AM
harley1615 Offline OP
I am putting a 700R-4 trans into my toyota. I was wondering if anyone knows if there is a good year range to use or not to use! I have a 2001 4.3L with a 4L60-E. I could use this one but I don't know if I should use the electronic trans or older version. Any info would help. Thanks
Re: 700R-4 ????? [Re: harley1615] #787749 02/09/07 08:49 PM
VanillaTHUNDA Offline
From what I understand the 700R4 is the more reliable of the two, since it uses purely mechanical components. The only advantage I can see to using the 4L60-E is that you can tweak the shift points at will.
Re: 700R-4 ????? [Re: harley1615] #787750 02/11/07 02:36 PM
Smoke Offline
The 700R4 ia a good transmission but you want the 86 or newer model unless your going to beef it up before installing. Lots of problems prior to 86 model. The newer models have larger servo and are a stronger tranny.
94 P/U Ex-Cab 3.0 Automatic 4X4
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5913 MB (Peak: 0.6443 MB) Data Comp: Off Server Time: 2026-06-23 14:23:58 UTC
