Alternator Bearings #787753 02/09/07 12:47 AM
drainsbe Offline OP
My alternator is howling... <img src="/forums/images/graemlins/scared.gif" alt="" /> I've looked here but it only talks about replacing the brushes... Can the bearings be replaced? Are there toyota part #s for the bearings?
Thanx in advance!
Dave
86 4Runner, 22R-EB
Re: Alternator Bearings [Re: drainsbe] #787754 02/09/07 03:35 AM
salvo Offline
if you pull them out and take them into a shop that specializes in bearings and crap they should be able to match them up for y a
Re: Alternator Bearings [Re: drainsbe] #787755 02/09/07 04:02 AM
kewlynx Offline
Yep, what Salvo said, unless you want to find an automotive electrical rebuilder like we have up here.
Breakdown is in the 93 FSM above if you want to give it a look.
**ubi apis- ibi salus**
Re: Alternator Bearings [Re: kewlynx] #787756 02/09/07 11:28 PM
drainsbe Offline OP
I'll give it a looksee... Thanx! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Dave
86 4Runner, 22R-EB
Re: Alternator Bearings [Re: drainsbe] #787757 02/10/07 12:30 AM
4Crawler Offline
If you can get the bearing dimensions (OD, ID and thickness, likely all metric), I may be able to source the bearings if you can't find them locally.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6056 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-07-17 04:59:26 UTC
