Page 3 of 6 1 2 3 4 5 6
Re: Started my rear axle swap [Re: sparkem] #788451 02/12/07 02:08 AM
LandRaider Offline
Ata boy!
Re: Started my rear axle swap [Re: sparkem] #788452 02/12/07 04:06 AM
motero Offline
Sounds great. I really want to see the u joint solution. On the u joints you used the joint from the 95 and it fit into the 91 shaft? There must be a diffrence between the years or the swb and long wheel base. There was a definate larger diffrent between the two on my swap. It was a 95 sr going to a 89 swb.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Started my rear axle swap [Re: motero] #788453 02/12/07 04:23 AM
sparkem Offline OP
What exactly was off?
On mine, the caps were the same diameter. A small height difference. The caps are not sticking out or pushed in, looks normal. I need to pump some grease in them and make sure the seals are seated correctly. I will get some pics of the gen1 and 95 Ujoints next to each other. I have one of the shafts somewhere. Let me go look.
Re: Started my rear axle swap [Re: sparkem] #788454 02/12/07 06:24 AM
PHIL_ Offline
Nice work buddy! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Also nice to be able to do it in a field... in FEBRUARY! <img src="/forums/images/graemlins/ignore.gif" alt="" />
(didn't know you'd swapped in the old style grille! Cool! And euro markers too! Way cool! <img src="/forums/images/graemlins/kewl.gif" alt="" /> )
Phil
Re: Started my rear axle swap [Re: PHIL_] #788455 02/12/07 03:40 PM
Mad_Scientist Offline
Nice work Sparky <img src="/forums/images/graemlins/kewl.gif" alt="" /> I bet that axle would work better on my truck though! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Started my rear axle swap [Re: Mad_Scientist] #788456 02/12/07 04:49 PM
F
fhuzz Offline
Hey Sparkem... nice work!!!!
Please excuse the ignorance, but the 1995 SR doner had the 3.5 engine right? Or can the SR have the 3.0 engine?
Thanks... and suweeeT!!!
dT
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
'89 Monty LWB auto, 3rd row seating, 95SR rear + coils, genII UCA's and calipers/rotors, dual bouncies.
Re: Started my rear axle swap [Re: fhuzz] #788457 02/12/07 05:34 PM
hmmmm... schweeet! Just out of curiousity, what's the gearing difference btwn the diff's?
Re: Started my rear axle swap [Re: off-roader] #788458 02/12/07 05:45 PM
Tag Offline
Since you have disc brakes in the rear what are you going to do about the proportioning valve? If I recall correctly disc brakes use alot more line pressure the drum.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Started my rear axle swap [Re: off-roader] #788459 02/12/07 06:29 PM
L
Lee N Offline
The '94+ SRs had a 3.5L motor. Gearing in these larger axles are 4.636 vs 4.625 for the 3.0L equipped trucks. The '92-'93 SRs had a 3.0L motor with 4.875 gears. I found one without the locker, but they did make them with a locker.
If anyone wants to donate to my Save A Monty fund, I would be glad to perform this upgrade. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/drunk.gif" alt="" />
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: Started my rear axle swap [Re: Lee N] #788460 02/12/07 07:22 PM
87Montero Offline
So this is a little off topic, but would the front gearset from a 92-93 SR with the 4.88 gears fit into a Gen 1 V6 front diff?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6511 MB (Peak: 0.7557 MB) Data Comp: Off Server Time: 2026-06-10 01:41:20 UTC
