no start problem
#788951
02/13/07 01:02 AM
hey all I am new to the board and am in desperate need of help!!
I have a 93 YJ w/4.0 manual trans i was originally having a sputtering/surging problem, but now the heep won't start!!
I have done everything i can think of which includes new MAP sensor new CPS on trans and under distributor checked vacuum lines replace TPS swapped ignition coil checked all grounds has spark has fuel cranks but won't start
any help would be great!! Please HELP!!!! Jay
Re: no start problem
[Re: jdawg13]
#788952
02/13/07 02:10 AM
What is fuel pressure, fuel present does not mean suffecient.
[Re: jdawg13]
#788953
02/13/07 02:17 AM
What he said! Was it mine I'd spray some carb cleaner in it while attempting to start her... If she pops and tries to run I'd look at the fuel pressure. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: jdawg13]
#788954
02/13/07 04:21 AM
just read the pressure on the rail it read 39 PSI this is driving me crazy!!!!
[Re: jdawg13]
#788955
02/13/07 05:49 AM
Might be the iac... Common to lose that feature.. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#788956
02/13/07 05:55 AM
just started, but doesn't want to stay running popping and backfiring the iac replaced 2 months ago? gonna make sure were at TDC now still trying....
[Re: jdawg13]
#788957
02/13/07 06:31 AM
Check for fouled sparky's. Gas soaked. JMHO. New sparky's, wires, cap, rotor...etc..?
C. <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
[Re: cjensen]
#788958
02/13/07 06:35 AM
i think the distributor was off a tooth, will replace plugs etc in AM gonna take it for a test drive right now to see it runs and idles pretty good considering plugs are munged up a bit now!! i'll let you guys know!!! Be right back!!! thanks all!!!!!!! jay
[Re: jdawg13]
#788959
02/13/07 07:16 AM
woooo hoooo !!!! We have a runner again!!!! thanks for the help guys!! i'll change the plugs/wires tomorrow and run it!!! thanks again jay
[Re: jdawg13]
#788960
02/13/07 03:42 PM
Ok wooo hooo now tell us how the dist got a tooth off in the first place??? Did YOU do it or did it do it all by itself.. I sure hope YOU did it! If it did it all by itself you really have a problem and I would not start her again till I got her repaired correctly. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6316 MB (Peak: 0.7388 MB) Data Comp: Off Server Time: 2026-06-22 10:33:23 UTCValid HTML 5 and Valid CSS
