Re: Should I buy ? 94 blown Engine?? [Re: 904runner2dr] #788973 02/14/07 02:51 AM
yotabob88 Offline OP
well i found out its is definitally a 22re and it has a hole in the block the side of and orange!! my guess oil pump went or timing chain broke and the rod went through the block so I need a whole new engine if I plan on taking this truck!!! what would you say is a reasonable bid for me to put on it considering it probly wasn't maintained great and it does show rust on the body probly new brakes, tires, clutch, and a lot of time with a shop vac and armoral for the interior $800 sound good ? too low? too high? $1000 ?
Re: Should I buy ? 94 blown Engine?? [Re: yotabob88] #788974 02/14/07 03:07 AM
kewlynx Offline
$800, take it or leave it. I'd offer him $500 first. <img src="/forums/images/graemlins/nana.gif" alt="" />
Couple years ago, I picked up an '83 SR5 with a toolbox in the bed and a full set of mounted winter tires--had the thrust washers sitting in the oil pan for $500.
A long block is going to cost you around $1600, unless you can find one here, given that you do NOT have a rebuildable core to turn in to someone.
Forget the Armorall; you're gonna need it for belts;hoses, etc. <img src="/forums/images/graemlins/shame.gif" alt="" />
EDIT Maybe you need a trip to Ohio For sale here
**ubi apis- ibi salus**
Re: Should I buy ? 94 blown Engine?? [Re: 904runner2dr] #788975 02/14/07 03:09 AM
bodo Offline
Toyotas are gold in Pensacola, the only $1500 ride you'll get here is a wreck or a hackjob 350/4.3 conversion. Here it's like they just go down to $3500 and stop nomatter what they are. We drool over $2000 running pickup/runners unless you can see through them.
Example 94' 2wd, V6, auto, 173,000 miles- $4900
89', 4wd, 22re, 5 speed, 187,000 miles, 33" tires-$4200
86', 4wd, 22re, 5 speed, ???,??? miles, see through bed-$2950. etc. etc.
Re: Should I buy ? 94 blown Engine?? [Re: yotabob88] #788976 02/14/07 07:11 AM
Snowtoy Offline
What is the asking price?
If it only has surface rust and it is dent free, $1k isn't a bad price, not here in CA anyways. I paid $1k for this '91 2yrs ago.
It had a hole in the #4 piston, a huge dent in the side of the bed, dents in the cab, both fenders, both bumpers were bad, a cracked windshield, an interior that hadn't been cleaned in atleast 10yrs, and the seats were both beyond keeping. I originally had planned to rebuild and resale it, but after assessing the costs I decided it would be better to build it for the trail.
Here in CA, clean,complete 3rd gen rigs with bad engines can go for $2500, and are rarely found for under $2k. You can come across one every now and then, but it is usually gone as soon as the add is posted.
You don't have to buy a new engine, I would look for a good used one, or one that needs to be repaired and rebuild it, you can usually find used working endines for under $600, and ones needing rebuilds under $300. A complete rebuild kit from [url=http://www.engnbldr.com/][/url] their master engine kit runs $219.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6106 MB (Peak: 0.6672 MB) Data Comp: Off Server Time: 2026-06-07 10:33:14 UTC
