Water pump replacement #789150 02/13/07 07:20 PM
trickster Offline OP
Noticed a slow drip of antifreeze today (85 22r) looks like its coming from behind the water pump pulley, so I am assuming its the pump going out. My clymer manual says to use a water resistant sealer on the new gaskets and on the pump bolt threads. Any suggestions or preferences as to what brand sealant?
Re: Water pump replacement [Re: trickster] #789151 02/13/07 07:24 PM
Staceman Offline
what brand sealant?
Almost any RTV will work. I prefer the gray stuff myself. Other people like other kinds. You'll need to add sealer to the threads of the bolt that runs through the center of the pump. It'll be self explainatory when you remove it.
Re: Water pump replacement [Re: Staceman] #789152 02/14/07 02:02 AM
TimsToyo Offline
Also check here for the FSM. It helps. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'86 Toyo 4wd
'04 600RR
Re: Water pump replacement [Re: trickster] #789153 02/14/07 03:11 AM
kewlynx Offline
Use a VERY THIN layer; otherwise you'll have goobers in the water jacket. <img src="/forums/images/graemlins/evil.gif" alt="" />
Also use a 1/4" drive rachet to reassemble, so you don't break off the studs. NO, no torque value.
The 3.0 pumps have a torque spec however.
Make sure you turn on the heater and leave the radiator cap off when you reservice the coolant, so as to burp ALL the air out.
**ubi apis- ibi salus**
Re: Water pump replacement [Re: kewlynx] #789154 02/14/07 04:53 PM
Thanks for the tips, got it done last nite, letting the silicone set up today, and will refill the coolant tonite after work. Kewlynx, the FSM doesnt list a torque spec, but my Clymer manual does (8-11 ft/lbs). I am curious why the recomendation for sealer on the bolt threads, it does not appear any are actually in water passages, though they are near.
Re: Water pump replacement [Re: trickster] #789155 02/14/07 06:08 PM
TimsToyo Offline
I was about to say I remember torquing mine to 9ft/lbs. Actually the torque specs I found are in the FSM under the "Standard Bolt Tightning Torque" section. You can find any bolts torque specs there.
'86 Toyo 4wd
'04 600RR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6769 MB) Data Comp: Off Server Time: 2026-06-20 00:29:46 UTC
