looking for wheels, help!!!
#789201
02/13/07 11:17 PM
okay, i'm really confused. i've been looking for some aftermarket wheels lately and everywhere i go i get the same answer. usually i'm told that no one makes a wheel that fits or that i'm crazy. please, someone help me with a web site or a company name or something. i really hate the factory wheels on this truck, even if one of you guys have an old set of aftermarket wheels that you don't want anymore. please help!!!!!!!!!
95 sportage, gone and severly missed. 94 camaro 5-speed v6 with a few addons. girlfriends 93 s-10 4.3 soon to be lifted and made into a pre-runner
Re: looking for wheels, help!!!
[Re: turtleskia]
#789202
02/14/07 12:56 AM
the rims are 5 on 5.5 same as a samuri, sidekick, tracker ect. i had one set of stock samuri rims on once and i have stock chrome tracker rims on right now if your looking for a cheap set of black rims go to summit racing i got a set of four 15x8 crager rims they were 37 dollars a piece. tells those tire salesmen to pull there head out of there a$$e$. <img src="/forums/images/graemlins/kewl.gif" alt="" />
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
[Re: kiarazy]
#789203
02/14/07 03:12 AM
American Egale style 058 15x7's fit nicly, as do any 5x5.5 rims off a Ford Ranger or F-100
08' Jeep Wrangler 64' Plymouth Sport Fury 383 58' Triumph TR-3A
[Re: Iron]
#789204
02/14/07 05:58 AM
okay guys, maybe i should have been more specific, i need to know what off-set the rims you guys own have on them. i called american racing wheels directly and they said the stock off-set was 45mm. if i knew what off-set everyone else was running, it would make things alot easier on me. thanks. turtle.
[Re: turtleskia]
#789205
02/14/07 07:06 AM
Turtle, I copied this off a web site:
1999-79 DODGE TRUCK - D100, W100, Ram 1500, Van/Wagon
1993-86 B200, D200, P200, W200, Ram 2500, Van/Wagon
1993-79 Ramcharger, W100 4X4
1974-69 W100 (W/16¢")
1996-75 FORD TRUCK - Bronco (Full Size), F100, P100, E100, E150, F150 (W/15")
1992-75 E100, E150, Econoline Vans, Club Wagons
1992-48 F100, F150, P100
1997-89 GEO TRUCK - Tracker
1984-66 IHC TRUCK - Series 100, 1010, Travelall, 150, 1000, 1100, 1110 (Ex 84-74 4WD)
1999-94 KIA TRUCK - Sportage
1986-79 PLYMOUTH TRUCK - Trail Duster 4X4
1998-89 SUZUKI - Sidekick (139.7mm)
1988-87 Samurai
1991-86 TOYOTA - Panel Van (139.7 mm)
All of these have 5 x 5.5 bolt pattern. I'm not sure about the offset.
Hope this helps.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: Iron]
#789207
02/14/07 03:01 PM
Kia Moderator
15 x 7 rims + 7 mm offset (1/4") with 31's (Actual diameter when new was 30.6") No clearance problems other than the usual rear fender/door area being trimmed and firewall seam folded (no sway bar). Rear minor scrubbing of RHS shock by tire on SEVERE articulation. 2" bodylift, 2.5" spring lift.
[Re: DamKia]
#789208
02/14/07 03:19 PM
there is a massive amount of discussion on different factory wheels for different vehicles that fit the Sportage as well as a massive amount of discussion about what fits and what don't. use the search function to give you some ideas.
anything with a 5-5.5" bolt pattern will fit. period. offset means nothing. backspacing is more a matter of how much you want the tires to stick out as far as LOOKS go. if you don't want a 30-31" tire to rub with no lift, then get somethign close to stock backspace, but other than that, you don't need all that information. just TELL them what you want. if they say they can't do it, walk.
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
[Re: Dave Scott]
#789209
02/14/07 10:02 PM
Dont forget to consider the size of the "hub hole". It has to be much larger than most rins to accomdate the locking hubs. Lots of factories wheels arn't big enough!
The Cheap cragars from Summit work great, mine are 4" offset.
[Re: Cen_Tex_KIA]
#789210
02/16/07 09:50 PM
Like Dave said, Back Spacing is more meaningful.
