help? Alternator tests okay but won't charge battery!
#789225
02/14/07 12:45 AM
My husband has a 88 Jeep Comanche that has over 300,000 miles on it. We recently had the entire clutch assembly replaced. Afterwards we started to experience problems with the alternator not charging the battery. We have a brand new battery, the alternator tests out okay and they are saying it is a ground wire problem but they can't seem to find it. Any ideas, thoughts, advice on how to fix this so the alternator will charge????? We would appreciate anything that you could do!
Re: help? Alternator tests okay but won't charge battery!
#789226
02/14/07 04:15 AM
Start by taking all the ground wires off and cleaning under them and then reinstalling! I do mean ALL of them. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
#789227
02/14/07 02:09 PM
I was thinking it sounds like a bad ground wire too, ie one from an engine to chassis, like around the bell housing which you just removed to change the clutch.....
#789228
02/15/07 01:55 AM
yeah I think you have to check for some poor grounding or loose connection. then try to re-install your Jeep clutch. hope it helps.
[Re: melody]
#789229
02/15/07 03:39 PM
WV...sometimes the problem can be attributed to the actual harness wires that connects to the alternator itself. This is a common problem with older Saturns.
The alternator also needs to put out at least 60% of it's peak Amp rating. For instanse, a 100Amp alternator needs to be making at least 60 Amps to sufficiently charge the battery.
[Re: 93yj]
#789230
02/15/07 06:00 PM
mabey the altinator just isnt putting out enough juice to charge the battery. when you did the test did you or they put a meter on it to see the volts its putting out. it should be around 12v. i think i would have to look it up but mabey someone else would know off the top of there head...
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
[Re: tcoff]
#789231
02/15/07 09:06 PM
tcoff...at least 14 volts is needed to charge a 12v battery. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6103 MB (Peak: 0.6872 MB) Data Comp: Off Server Time: 2026-06-15 17:15:11 UTCValid HTML 5 and Valid CSS
