Page 2 of 3 1 2 3
Re: 4.0 ltr in my Raider [Re: BobShaw] #789716 02/17/07 01:18 AM
DARTH_RAIDER Offline OP
Thanks for the heads up Bob. I intend to swap the whole drivetrain, I have the entire truck so I was plannin on using the rad too just to make it easier. I
Mark
Re: 4.0 ltr in my Raider [Re: DARTH_RAIDER] #789717 02/17/07 01:09 PM
Y
yankneck696 Offline
I work in a salvage yard & REFUSE to sell an exploder transmission. It's just plain junk. Not designed for the HP & weight of the vehicle.
If you insist, get a FULL rebuild from a reputable shop.
We gave up selling those transmissions after pulling 4 to get 1 good one, even though we tested them before pulling them. Line pressures were in spec.
I would go for the 4.3 swap, as the engine/trans is much healthier & you can find a donor for it cheap.
2.8 would be a waste in my opinion, but the 2.5 5speed & 3.4L might be a go. Just change the head gaskets, as they have issues. Also, before installing any engine, swap out the seals & water pump.
Good luck...
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: 4.0 ltr in my Raider [Re: yankneck696] #789718 02/17/07 10:57 PM
Thanks Yank. Ive already been on the horn to our tranny shop about the A4LD. I figured while i have it out I might as well do the rebuild. At least ill save on the re&re <img src="/forums/images/graemlins/wink.gif" alt="" />
Mark
Re: 4.0 ltr in my Raider [Re: yankneck696] #789719 02/19/07 06:31 PM
L
Lee N Offline
<snip>
Good luck...
Ed
One thing to consider with the 3.4L swap, if you use an Isuzu bell housing on the A44DL, you can bolt up the 3.4L V-6 to it. My research shows specifically it would need to be a '91-'94 Isuzu pick-up with a 3.1L V-6. Also, a Cadillac 4.1, 4.5, 4.9 V8 or Northstar V8 uses this same bolt pattern.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: 4.0 ltr in my Raider [Re: Lee N] #789720 02/19/07 06:48 PM
dylanb Offline
hmmm, northstar in a montero....
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: 4.0 ltr in my Raider [Re: Lee N] #789721 02/19/07 07:28 PM
toddstidham1 Offline
So do I have this right in my head...a 91-94 Isuzu 3.1L automatic transmission bell housing will mount to a mitsubishi km148 automatic?
And don't get too excited with the caddy 4.x liter, cast iron heads sandwiched between an aluminum block and intake IS trouble. I've rebuilt a fair share of them, and you must use GM's special coolant pellets after the rebuild. Essentially stop leak for the anti-freeze. <img src="/forums/images/graemlins/barf.gif" alt="" /> They do make decent power though!
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: 4.0 ltr in my Raider [Re: toddstidham1] #789722 02/19/07 07:37 PM
Ohh Vega horrers revisited, thank golly for new style headgaskets. At least I hope they use metal shim gaskets.
Re: 4.0 ltr in my Raider [Re: OldColt] #789723 02/19/07 07:53 PM
Well, not quite Vega horrors, they did use cast iron piston sleeves and the head gaskets were pretty stout looking. The problem was the head bolts, they are crazy long and the threads are in the very bottom of the block. So you're torquing a steel bolt in aluminum threads. <img src="/forums/images/graemlins/zombie.gif" alt="" /> I don't know how many times they'd strip and you'd tear down again to heli-coil the block. New bolts are a must!
-Todd
Re: 4.0 ltr in my Raider [Re: dylanb] #789724 02/20/07 10:17 PM
ryany Offline
Wow, that gets the gears cranking in my head. My dad has a complete Northstar engine from a 97 DeVille that he bought to build a sandrail around, but ended up buying a complete sandrail instead. I think it's rated at 275hp stock. Then I go to www.chrfab.com & drool a little bit, thinking about a 450hp Gen I 2 door.
95 Montero SR
Re: 4.0 ltr in my Raider [Re: ryany] #789725 03/15/07 02:52 PM
OK so i hogged the tranny out of the exploder on sunday and took it into our tranny shop tuesday. The forward clutches were burnt and the pump gear is worn. 300 bucks later fix em up bumba clot. I'm doin it. Gonna start pullin the engine on the exploder this this weekend but i think i'll get the raider out wheelin a couple of times this year before I immobilize it. I'll keep you guy posted, and definatly take pics.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6419 MB (Peak: 0.7504 MB) Data Comp: Off Server Time: 2026-06-20 22:55:48 UTC
