Re: Clutch Problem - please help [Re: ocaptainmycaptain] #790311 02/18/07 04:49 PM
canuck Offline
Seems to be confusion here.... The clutch has its own master cylinder which is bolted to the firewall with a slave cylinder attached to the bell housing on the passengerside. The clutch "system" has nothing to do with the brake system. The brake system has its own master cylinder which is bolted onto the booster. Both use the same fluid DOT 3 brake fluid. The bleeding process is the same for both systems.
Keep the Shiney Side up. Support our troops.
Re: Clutch Problem - please help [Re: canuck] #790312 02/18/07 05:05 PM
DRTDEVL Offline
If the reservoir was empty, the fluid went somewhere...
Find out where it went... Either a bad master or slave is letting it all out.
Re: Clutch Problem - please help [Re: DRTDEVL] #790313 02/18/07 06:26 PM
OOP'S Offline
Lets see, your truck is a 94, that makes it thirteen years old. The clutch system is more then likely the same age. I would go with OEM parts.
This place has pretty good prices on OEM parts:
http://www.trademotion.com/partlocator/index.cfm?siteid=214074
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Clutch Problem - please help [Re: OOP'S] #790314 02/18/07 07:03 PM
O
ocaptainmycaptain Offline OP
You guys are truly a wealth of information. I'm going to check it out today - see if any fluid has leaked out anywhere and also see how the clutch pedal feels and whether I can shift or not. If the reservoir is empty then I know I need to replace parts right away. If it's still full, I'll try bleeding it and see what happens. Either way, though, I think for long-term peace of mind, I'll end up replacing both the master and slave. Prices don't look that bad and the work seems easy enough to do. Thanks for all the advice. I'll keep you posted on my progress. Here is a pic of my truck. Not even 130k on her.
94 4x4 Extended Cab V6 3.0L 5-speed
Re: Clutch Problem - please help [Re: OOP'S] #790315 02/18/07 08:58 PM
TimsToyo Offline
Why would he need to bleed the brakes if it was the clutch MC that was empty???????
Check the firewall behind the dash (inside behind the clutch pedal)to see if fluid is leaking down there. If it is replace the clutch MC and slave cylinder.
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Yes I meant the MC for the clutch. <img src="/forums/images/graemlins/shiner.gif" alt="" />
'86 Toyo 4wd
'04 600RR
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6138 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-11-16 08:55:12 UTC
