help oil in antifreeze
#790505
02/18/07 07:13 PM
i noticed today that i am starting to get oil in my antifreeze.my oil is fine no antifreeze in it.and when you take the cap off of radiator there is a little pressure coming out after the cap has been off a while.so is it a headgasket or maybe timing chain that put a hole in the cover? also starting to get a knocking sound could this have to do with antifreeze problem?mite need to pull a rebuild the whole motor?or maybe just head gasket and timing chain?any info would be appreciated
Re: help oil in antifreeze
[Re: smokn03]
#790506
02/18/07 08:55 PM
First pull the valve cover and check the timing chain guide on the driver's side. If it's still there then your timing chain cover should be ok. Next run a compression test and a leak down test on the cylinders to see where the leak is.
The knock shouldn't be from the coolant if it isn't getting into your oil. The knock may be the timing chain.
'86 Toyo 4wd '04 600RR
[Re: TimsToyo]
#790507
02/18/07 09:03 PM
thanks i will check that stuff first.also truck only has 135000 miles thought these trucks lasted forever <img src="/forums/images/graemlins/scared.gif" alt="" />
[Re: smokn03]
#790508
02/19/07 02:36 AM
and how many miles before bottom end needs rebuilt?
[Re: smokn03]
#790509
02/19/07 04:44 AM
Well maintained, 250k isn't abnormal (with at least one HG and timing chain setup).
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#790510
02/20/07 05:19 AM
is a graphite headgasket good or bad seen one on ebay wondering if its junk or normal and can you convert timing chain from 82 22r thats double row chain?
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6068 MB (Peak: 0.6757 MB) Data Comp: Off Server Time: 2026-06-24 15:23:03 UTCValid HTML 5 and Valid CSS
