Transmission fluid #790620 02/19/07 03:04 AM
A
Alloush Offline OP
I have an 05 TJ. I heard that you dont need to change the transmission fluid on an 03 or newer if it's a manual. That the fluid will stay good for the life of the vehicle. Is this true?
05 TJ 2.25 BB. Skyjacker hydro 7000 shocks.
Re: Transmission fluid [Re: Alloush] #790621 02/19/07 04:43 AM
F
Fred Blackstone Offline
That only is true under "normal" driving conditions! If you dunk your Jeep in deep water and get water in your transmission, you'll need to change the tranny fluid. You should get a copy of an owner's manual and read this stuff for yourself. Check out mopar's new HOAT antifreeze/coolant!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5858 MB (Peak: 0.6334 MB) Data Comp: Off Server Time: 2026-06-21 18:47:25 UTC
