Re: The friggen upper arm bolt again [Re: bretwalda] #790867 02/21/07 06:59 PM
shadowgear Offline
Looked into this locally for you and the best that my supplier can do is M12 x 1.25 x 70mm in an 8.8 metric or M12 x 1.75 x 70mm in a 10.9. Hopefully you find something that works. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Raider 2.6L - SW Hubs, Weber 32/36, Off-road Pkg - Dead
'88 Monty 2.7L - 5" Lift, Weber 38, 33's, Dual Fans, Dual bouncy (more goodies to install) - Still Kicking.
'03 Monty Sport - XLS, BFG A/T's - Dead
Re: The friggen upper arm bolt again [Re: FrankR] #790868 03/02/07 04:25 PM
bretwalda Offline OP
Thank you guys. Thanks Frank for the info. I'm gonna go with that alternative as I'm quite sure there isn't any other. <img src="/forums/images/graemlins/frown.gif" alt="" />
If its good enough for a Ford then its.... <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
concreteprinter.com
Re: The friggen upper arm bolt again [Re: bretwalda] #790869 03/02/07 05:49 PM
W
Winston Offline
The difference in pull-out and fatique strength is not significant enough for you to worry about. There is plenty of safety factor in that original bolt selection by the mfg.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: The friggen upper arm bolt again [Re: Winston] #790870 03/02/07 07:46 PM
toddstidham1 Offline
You could always drill out the holes and move up to a 9/16 fine thread US Grade 8 bolt. That would be closer to 14mm diameter. If you're worried about pull out on the threads, double nut it! <img src="/forums/images/graemlins/kewl.gif" alt="" /> that should net more overall pull out strength then the single fine thread nut.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6074 MB (Peak: 0.6630 MB) Data Comp: Off Server Time: 2026-11-02 07:41:58 UTC
