Rear Bumper Ideas #790949 02/20/07 05:18 AM
Jake97T Offline OP
Due to certain members of my state law enforcement agency i am fored to fabricate a rear bumper...looking for ideas, it will be 1.5" .120 wall tubing with a spare tire carrier hopefully incorporated into it somehow, although i dont want the tire vertical...asking for ideas/input...
Re: Rear Bumper Ideas [Re: Jake97T] #790950 02/21/07 09:16 AM
BamZipPow Offline
I thought trucks weren't required to have rear bumpers... <img src="/forums/images/graemlins/frown.gif" alt="" />
I did find this...
Re: Rear Bumper Ideas [Re: Jake97T] #790951 02/21/07 12:10 PM
CJMT100 Offline
I say you build it out of square stock, beefy and make it closely resemble the original bumper shape but wrap it around the sides of the body more. Then add a tire carrier to it.
Re: Rear Bumper Ideas [Re: CJMT100] #790952 02/21/07 02:29 PM
jmoser Offline
I vote for 'C' channel vs square stock - by all means wrap it around the rear corners if possible. If you are not worried about crash functionality then aluminum is a good choice weightwise.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: Rear Bumper Ideas [Re: jmoser] #790953 02/21/07 04:46 PM
ErikB Offline
Toyota Moderator
Square would be strongest, C-channel the heaviest (my last choice), and the round tubing would be the lightest and easiest to have bent to make it look good.
Seeing as how your truck is basically a desert style truck, I'd go with the round tubing for looks and light weight. It will still be much stronger and give better protection than the stock tinfoil one.
Anyway, as for design- that is more up to personal preference. I was looking at desert trucks for ideas, but it looks like they don't even usually run a rear bumper.
This one looks a little more tire-carrier than bumper. If it were me, I'd want it to provide a little more protection and probably wrap around the corners, but I'm not sure what you're looking for. I'm not sure it would satisfy your local LEO's.
Maybe something that was kind of a combo of the tire carrier above and this Allpro bumper:
Or another from Marlin:
http://home.4x4wire.com/erik
Re: Rear Bumper Ideas [Re: ErikB] #790954 02/21/07 05:53 PM
surlynkid Offline
there was a guy way back that posted on our boards that ran desert style stuff that had a 4" lift and 3" BL. iirc, he had a rear tube bumper setup for desert style. i just remember a picture or two he posted.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Rear Bumper Ideas [Re: surlynkid] #790955 02/21/07 06:07 PM
ErikB Offline
Toyota Moderator
This guy?
Re: Rear Bumper Ideas [Re: ErikB] #790956 02/21/07 06:19 PM
Kookadala Offline
You can get beefy like this if you want
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: Rear Bumper Ideas [Re: ErikB] #790957 02/21/07 07:20 PM
surlynkid Offline
damn you're good. yup - he is the one.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Rear Bumper Ideas [Re: surlynkid] #790958 02/21/07 07:23 PM
CJMT100 Offline
I was thinking more along the lines of the ones on the runners posted here: http://www.yotatech.com/showthread.php?t=107675
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6364 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-05-28 17:16:23 UTC
