Rear Bumper Ideas
#790949
02/20/07 05:18 AM
Due to certain members of my state law enforcement agency i am fored to fabricate a rear bumper...looking for ideas, it will be 1.5" .120 wall tubing with a spare tire carrier hopefully incorporated into it somehow, although i dont want the tire vertical...asking for ideas/input...
Re: Rear Bumper Ideas
[Re: Jake97T]
#790950
02/21/07 09:16 AM
I thought trucks weren't required to have rear bumpers... <img src="/forums/images/graemlins/frown.gif" alt="" /> I did find this...
[Re: Jake97T]
#790951
02/21/07 12:10 PM
I say you build it out of square stock, beefy and make it closely resemble the original bumper shape but wrap it around the sides of the body more. Then add a tire carrier to it.
[Re: CJMT100]
#790952
02/21/07 02:29 PM
I vote for 'C' channel vs square stock - by all means wrap it around the rear corners if possible. If you are not worried about crash functionality then aluminum is a good choice weightwise.
Jeff 96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
[Re: jmoser]
#790953
02/21/07 04:46 PM
Toyota Moderator
Square would be strongest, C-channel the heaviest (my last choice), and the round tubing would be the lightest and easiest to have bent to make it look good. Seeing as how your truck is basically a desert style truck, I'd go with the round tubing for looks and light weight. It will still be much stronger and give better protection than the stock tinfoil one. Anyway, as for design- that is more up to personal preference. I was looking at desert trucks for ideas, but it looks like they don't even usually run a rear bumper. This one looks a little more tire-carrier than bumper. If it were me, I'd want it to provide a little more protection and probably wrap around the corners, but I'm not sure what you're looking for. I'm not sure it would satisfy your local LEO's. ![[Linked Image]](http://chaosfab.com/photo/images/P1062182.jpg) Maybe something that was kind of a combo of the tire carrier above and this Allpro bumper: ![[Linked Image]](http://allprooffroad.com/images/stories/bumpers/rear_bumper_back_l.jpg) Or another from Marlin: ![[Linked Image]](http://www.marlincrawler.com/images/rearbumperb_250.jpg)
[Re: ErikB]
#790954
02/21/07 05:53 PM
there was a guy way back that posted on our boards that ran desert style stuff that had a 4" lift and 3" BL. iirc, he had a rear tube bumper setup for desert style. i just remember a picture or two he posted.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
[Re: surlynkid]
#790955
02/21/07 06:07 PM
Toyota Moderator
This guy? ![[Linked Image]](http://home.4x4wire.com/erik/t100/justins_t100flex.jpg)
[Re: ErikB]
#790956
02/21/07 06:19 PM
You can get beefy like this if you want ![[Linked Image]](http://www.webperception.com/jdouglas/images/jpg/rbump.jpg)
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc. 99 F-350 4x4 superduty supercab turbodiesel longbed
[Re: ErikB]
#790957
02/21/07 07:20 PM
damn you're good. yup - he is the one.
