92 runner trans swap auto to manual
#791005
02/20/07 08:53 AM
need some help here, im about to atempt the 3.4 swap and i want to get rid of the automatic transmission for manual. since the 99 tacoma 3.4 bolts up to both types of transmissions for the 92 runner r150 i belive. since im going from auto to manual i know im gonna be purchasing many parts for example clutch lines, brake/clutch pedal assemblies but thats about all i no of ive cheacked out the fsm but im still at a loss of basic info so if u could help me it would be appreciated
--jonathan
Re: 92 runner trans swap auto to manual
[Re: jonny_fookou]
#791006
02/20/07 10:49 AM
Clutch master cylinder and slave cylinder. If you are using the 5 speed from a 2nd Gen 4runner it should fit. May need to check the rear tranny mount to see if the auto is the same as the manual and change it if you need too. I'm sure you already know you will need the manual tranny ECU for the 3.4. The wiring to the tranny will be added in your swap, neutral start, reverse light. The ORS harness that I got had wires in place and I just spliced on the appropriate connector and it was done. You may want to get the tranny connectors from the vehicle you get the manual tranny from.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4 1995 4Runner V6 Auto 2WD
[Re: Kutter]
#791007
02/20/07 11:01 AM
kutter i should almost be payin u for all the info u give me i ask a question and u help thank u man
--jonathan
[Re: jonny_fookou]
#791008
02/20/07 11:06 AM
so that is all the parts i need for the trans swap
--jonathan
[Re: jonny_fookou]
#791009
02/20/07 11:58 AM
There is an electric button available on manual tranny vehicles that lets you bypass the clutch. It is handy and you may want to get that as well from the donor manual tranny vehicle.
Other than those things you mentioned it should just about be it for installing a manual. For the swap if you do the body lift you will want to probably install a short throw shifter to raise the sifter up and get clearance on the hole in the floor.
Have you lined up a 3.4 donor?
[Re: Kutter]
#791010
02/20/07 02:29 PM
Scroll down through this link. It shows the differences of peddle brackets and some of what is required to install the Manual in place of auto bracket. http://www.pirate4x4.com/forum/showthread.php?t=496869
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6084 MB (Peak: 0.6780 MB) Data Comp: Off Server Time: 2026-10-21 19:04:23 UTCValid HTML 5 and Valid CSS
