Page 6 of 19 1 2 4 5 6 7 8 18 19
Re: Ranger - Montero Diesel Swap thread [Re: LandRaider] #791353 10/22/07 07:21 PM
samwe Offline
My tranny hung up too. I ended up taking the T-case off then I could easily install the tranny with no problems.
Re: Ranger - Montero Diesel Swap thread [Re: LandRaider] #791354 10/23/07 08:54 PM
pmontero Offline OP
I was dove hunting in South Texas along the Mexican border last weekend and just got back today. My friend is coming down next weekend and we're going to pull the engine and tranny together. We're hoping we can pry it apart without cutting into the bell housing. (that's the worst case so we can remove the clutch basket and flywheel bolts.)
Pmontero
You gonna stop by and see me on the way back to ATL?
LR,
I would have stopped by but I don't think I could convince the Delta pilot to divert and stop by... <img src="/forums/images/graemlins/lol.gif" alt="" />
Pmontero
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791355 11/04/07 03:28 AM
pmontero Offline OP
I got the engine out today. There was a needle bearing resting near the bolt holes in the crankshaft after we pulled the flywheel so it looks like the pilot bearing was frozen on the input shaft.
I have some cleanup to do on the engine and fuel system work in the Montero and on the engine before it goes in the Montero.
One step closer!
Pmontero
'87 Montero Diesel
and more...
Greasology
NotPetroleum
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791356 11/04/07 09:16 PM
dylanb Offline
Just a quick update from my end as well.... progress is slow due to school. Got my oil pan and pickup issues settle thanks to some stock pieces from PA_JERO. It also looks like I won't have to have a new PS hose fabbed. The fitting on the mitsu hose will fit the Ranger pump as long as it reaches, so we'll find out for sure when I try to place the engine. Next order of business is figuring out motor mounts.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: Ranger - Montero Diesel Swap thread [Re: dylanb] #791357 11/06/07 05:08 AM
PA_JERO Offline
I may have some extra mounts, if you are refering to the motor mount brackets that bolt to the block.
Re: Ranger - Montero Diesel Swap thread [Re: PA_JERO] #791358 11/06/07 08:46 AM
dylanb Offline
I have a pair from the ranger, but they are nowhere near being the same as the 2.6 mounts like I heard they were. Can you post a picture of the mounts to see if they're different than what I have? thanks,
Dylan
Re: Ranger - Montero Diesel Swap thread [Re: dylanb] #791359 11/06/07 08:36 PM
8
89Diesel Offline
The motor mounts off a 2.6 D50 interchange with the ranger. The D50's bolt on farther back than the ranger. The extra bolt holes are hidden by the ranger mount.
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
Re: Ranger - Montero Diesel Swap thread [Re: 89Diesel] #791360 11/07/07 04:56 AM
PA_JERO Offline
the mounts that I have look like the pic above. They came off of a 2.3 out of a mighty max
Re: Ranger - Montero Diesel Swap thread [Re: PA_JERO] #791361 11/07/07 06:26 AM
dylanb Offline
hmmm.... the bolt holes on my block don't look like they're even close to lining up with the 2.6 mounts... i'll check again/ post a pic this weekend when I go home.
Re: Ranger - Montero Diesel Swap thread [Re: dylanb] #791362 11/07/07 04:07 PM
8
89Diesel Offline
Ya, I didn't think mine would bolt up either, but when I took the other mounts off, the top holes weren't used and hidden in behind. It still didn't look like they would work until I actually held the new mounts right up to it.
The rubber part of the mounts, I had just left in the truck, but found out you have to modify the driver side. There is a U shaped iron that goes around the outside of the rubber (pass. side doesnt have this) So either cut the rear of the U off (I did) or swap mounts side-for-side. The iron wont interfere with anything on the pass. side (I should have swapped them, but engine was in and hindsight is 20-20). This iron hits the solenoid on the starter if left in place.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6539 MB (Peak: 0.7587 MB) Data Comp: Off Server Time: 2026-05-29 15:21:56 UTC
