Re: Ranger - Montero Diesel Swap thread
[Re: LandRaider]
#791353
10/22/07 07:21 PM
My tranny hung up too. I ended up taking the T-case off then I could easily install the tranny with no problems.
[Re: LandRaider]
#791354
10/23/07 08:54 PM
I was dove hunting in South Texas along the Mexican border last weekend and just got back today. My friend is coming down next weekend and we're going to pull the engine and tranny together. We're hoping we can pry it apart without cutting into the bell housing. (that's the worst case so we can remove the clutch basket and flywheel bolts.)
Pmontero You gonna stop by and see me on the way back to ATL? LR, I would have stopped by but I don't think I could convince the Delta pilot to divert and stop by... <img src="/forums/images/graemlins/lol.gif" alt="" /> Pmontero
[Re: pmontero]
#791355
11/04/07 03:28 AM
I got the engine out today. There was a needle bearing resting near the bolt holes in the crankshaft after we pulled the flywheel so it looks like the pilot bearing was frozen on the input shaft. I have some cleanup to do on the engine and fuel system work in the Montero and on the engine before it goes in the Montero. One step closer! Pmontero ![[Linked Image]](http://notpetroleum.com/4d55victory.jpg)
[Re: pmontero]
#791356
11/04/07 09:16 PM
Just a quick update from my end as well.... progress is slow due to school. Got my oil pan and pickup issues settle thanks to some stock pieces from PA_JERO. It also looks like I won't have to have a new PS hose fabbed. The fitting on the mitsu hose will fit the Ranger pump as long as it reaches, so we'll find out for sure when I try to place the engine. Next order of business is figuring out motor mounts.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
[Re: dylanb]
#791357
11/06/07 05:08 AM
I may have some extra mounts, if you are refering to the motor mount brackets that bolt to the block.
[Re: PA_JERO]
#791358
11/06/07 08:46 AM
I have a pair from the ranger, but they are nowhere near being the same as the 2.6 mounts like I heard they were. Can you post a picture of the mounts to see if they're different than what I have? thanks, Dylan
[Re: dylanb]
#791359
11/06/07 08:36 PM
The motor mounts off a 2.6 D50 interchange with the ranger. The D50's bolt on farther back than the ranger. The extra bolt holes are hidden by the ranger mount. ![[Linked Image]](http://img50.imageshack.us/img50/9914/002nj9.jpg)
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
[Re: 89Diesel]
#791360
11/07/07 04:56 AM
the mounts that I have look like the pic above. They came off of a 2.3 out of a mighty max
[Re: PA_JERO]
#791361
11/07/07 06:26 AM
hmmm.... the bolt holes on my block don't look like they're even close to lining up with the 2.6 mounts... i'll check again/ post a pic this weekend when I go home.
[Re: dylanb]
#791362
11/07/07 04:07 PM
Ya, I didn't think mine would bolt up either, but when I took the other mounts off, the top holes weren't used and hidden in behind. It still didn't look like they would work until I actually held the new mounts right up to it. The rubber part of the mounts, I had just left in the truck, but found out you have to modify the driver side. There is a U shaped iron that goes around the outside of the rubber (pass. side doesnt have this) So either cut the rear of the U off (I did) or swap mounts side-for-side. The iron wont interfere with anything on the pass. side (I should have swapped them, but engine was in and hindsight is 20-20). This iron hits the solenoid on the starter if left in place.
