Page 16 of 19 1 2 14 15 16 17 18 19
Re: Ranger - Montero Diesel Swap thread [Re: dudly] #791453 08/10/10 04:51 AM
spencevans Offline
Where are we at with this swap? Hold on to those Ranger Flywheels, they are really rare. I have been searching high and low for a Ranger flywheel for days, but I think I found one in Georgia.
Spence
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: Ranger - Montero Diesel Swap thread [Re: spencevans] #791454 08/14/10 11:59 PM
pmontero Offline OP
Spence,
Funny you should ask this week! I had to put it down for a few months due to extreme heat but picked it back up today. I took the Ranger flywheel, Montero flywheel, a brand new Montero clutch kit and new Ranger clutch kit to the machine shop to get the Ranger flywheel drilled for the Montero clutch and the pilot bearing pressed. It should be ready by next weekend.
I need to change the rear main seal on the engine and get the power steering hose fabricated. That should wrap up the fabrication pieces and I can drop the motor in.
Actually, I still need to sort out the accelerator cable. I may end up getting some fabrication done to the Montero bracket and connector on the cable to fit the throttle on the injection pump.
-Pmontero
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791455 08/17/10 09:37 PM
spencevans Offline
I am in desperate need of that ranger flywheel you willing to make a trade for a Mitsubishi 4d55 flywheel?
Spence
Re: Ranger - Montero Diesel Swap thread [Re: spencevans] #791456 08/26/10 01:02 AM
pmontero Offline OP
I picked up the drilled Ranger flywheel fitted to the Montero 2.6 Gas clutch today. Here are the pics of it assembled for test fit. (including Montero throwout bearing to the right)
I had a new Ranger pilot bearing pressed into the flywheel as well. This is ready to go on the crankshaft so I can drop the engine in!
I'm going to change the rear main seal and get the power steering hose sorted out and then it will be time to drop it in and crank it up!
-Pmontero
'87 Montero Diesel
and more...
Greasology
NotPetroleum
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791457 08/27/10 12:36 AM
spencevans Offline
That's a sweet looking setup.
Spence
Re: Ranger - Montero Diesel Swap thread [Re: spencevans] #791458 11/21/10 06:02 PM
JeffatTireBalls Offline
Updates?
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.p...ID=#Post1240274
Re: Ranger - Montero Diesel Swap thread [Re: JeffatTireBalls] #791459 12/10/10 04:04 AM
I have a brand new 4D56 crate motor on the way and wi <img src="/forums/images/graemlins/kewl.gif" alt="" />
99 Montero SR
Re: Ranger - Montero Diesel Swap thread [Re: JeffatTireBalls] #791460 12/16/10 03:33 AM
pmontero Offline OP
I have some vacation starting next week through the end of the year. I'm hoping to finish the motor and get it in the truck if it's not too cold to turn a wrench!
-Pmontero
'87 Montero Diesel
and more...
Greasology
NotPetroleum
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791461 04/22/11 11:18 PM
-Pmontero
Well? <img src="/forums/images/graemlins/sleeping.gif" alt="" />
99 Montero SR
Re: Ranger - Montero Diesel Swap thread [Re: JeffatTireBalls] #791462 06/12/11 07:46 PM
pmontero Offline OP
still tucked away in the garage awaiting bandwidth... <img src="/forums/images/graemlins/sleeping.gif" alt="" />
(however, the Porsche Boxster EV had it's first run on the pavement last weekend!)
-pmontero
'87 Montero Diesel
and more...
Greasology
NotPetroleum
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6544 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-06-21 00:09:06 UTC
