Center Support Bearing
#791484
02/21/07 03:28 AM
i'm working on a 2wd toyota pickup and the carrier bearing bracket has been mutilated. i'm wondering how it bolts in... like this: ![[Linked Image]](http://www.geocities.com/wingnutooa/carrier1.JPG) or like this: ![[Linked Image]](http://www.geocities.com/wingnutooa/carrier2.JPG)
Re: Center Support Bearing
[Re: Wing_Nut_OOA]
#791485
02/21/07 04:14 AM
so apparently this is greek?
[Re: Wing_Nut_OOA]
#791486
02/21/07 04:20 AM
I just replace the center bearing on my '85 4wd two weeks ago. Mine mounted up like your first drawing. You could also look at the way the frame is in the mounting location and match it up. My guess is that it will be like your first drawing. But check the mounting location and go from there, it should be able to only mount one way.
Chris
#791487
02/21/07 04:25 AM
the mount for the bearing that is welded to the crossmember has been mutilated by the drivline breaking and slamming around.
so i really wasnt sure which way the tabs went.
[Re: Wing_Nut_OOA]
#791488
02/21/07 05:23 AM
i guess i'll just guess and fab a bracket out of 1/4 inch steel..
piece of cake!
[Re: Wing_Nut_OOA]
#791489
02/23/07 12:47 AM
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6058 MB (Peak: 0.6755 MB) Data Comp: Off Server Time: 2026-10-21 21:48:11 UTCValid HTML 5 and Valid CSS
