Lost a turn signal and I don't know why...
#791576
02/21/07 05:50 AM
Lost my left front turn signal the other day. I figured it was just another bulb so I went to put a new one in and the old one was still fine. Tried the new one just to be sure and still no go. Just the one front corner; the rest still work. The left side does the spastic blinker just like if the bulb were burnt but I can't find anything wrong with the wiring. Is is possible for the little fuse/controller under the dash to only partially go? Any ideas?
Re: Lost a turn signal and I don't know why...
[Re: Poor A$$ Stock '93]
#791577
02/21/07 05:59 AM
Check the connector itself, the little conductors inside. I have seen them corrode to the point they no longer make contact with the bulb. That will look to the flasher like a burnt out bulb and it'll flash faster.
[Re: 4Crawler]
#791578
02/21/07 06:47 AM
It looked ok but I will check it again just to make sure.
#791579
02/21/07 07:58 PM
While looking for corrosion (on the ground wire too), check for volts. If none, go back from there.
'80 4X4 Longbed
[Re: Stevie]
#791580
02/22/07 01:34 AM
turn on your 4 way flashers ... If there working , you can narrow it dowm to either the turn sign. combi switch or the bulb /ground .
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6031 MB (Peak: 0.6673 MB) Data Comp: Off Server Time: 2026-07-17 01:49:27 UTCValid HTML 5 and Valid CSS
