Gen1 Maintenace Required light #791883 02/22/07 11:36 PM
8
89IsMine Offline OP
So I was out at lunch today with my wife, and both of us were watching the odometer in the Raider tick over 200,000, and almost immediately the "Maint. req'd" light flashed on and I thought to myself "well, DUH!" <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I'm almost tempted to leave it on as a reminder -- I really like my Raider, but it's definitely NOT a low-maintenance vehicle <img src="/forums/images/graemlins/smile.gif" alt="" />
Just something I found amusing today and thought I'd share <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
Re: Gen1 Maintenace Required light [Re: 89IsMine] #791884 02/22/07 11:44 PM
monte3 Offline
Same thing a month ago, except 150,000. Another 50 to go...
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Gen1 Maintenace Required light [Re: 89IsMine] #791885 02/23/07 08:24 AM
L
Lester Offline
Does this even exist in our Gen 1? I have never come across it before except for the alternator, brake, hi beam, and one other I can't recall now. Definitely not any maintenance required light.
Re: Gen1 Maintenace Required light [Re: Lester] #791886 02/23/07 04:07 PM
dadrab Offline
Yep. In the v-6s there was a "Maint. Reqd." light.
with awesome audio.
Re: Gen1 Maintenace Required light [Re: 89IsMine] #791887 02/23/07 05:23 PM
Eric,
You know how to shut if off after you do the maintenance right? Let me know if you don't.
Ray
Re: Gen1 Maintenace Required light [Re: off-roader] #791888 02/23/07 06:53 PM
8
89IsMine Offline OP
Eric,
Ray
I do Ray -- thanks for checking! I just found it amusing, and figured someone else might get a kick out of it as well. I also found the line about the warning light in the FSM amusing... Note that the warning lights bulb should be removed after the 120,000 mileage I guess someone must have forgotten to do this <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Eric W.
Re: Gen1 Maintenace Required light [Re: 89IsMine] #791889 02/23/07 08:05 PM
Dan1171 Offline
There is also a switch on the same panel to reset the light if you dont want to remove it. I just removed mine and didn't think about it again.
Re: Gen1 Maintenace Required light [Re: dadrab] #791890 02/24/07 01:06 AM
L
Lester Offline
Opps, I missed the sig on the 6 banger. I was thinking of the 4. Cheers.
Re: Gen1 Maintenace Required light [Re: 89IsMine] #791891 12/08/07 12:32 AM
1
1009 Offline
What is the procedure to cancel the light
89 Dodge Raider V6 Auto Black n Gold
Re: Gen1 Maintenace Required light [Re: 1009] #791892 12/08/07 12:37 AM
sparkem Offline
Pull off the plastic thing behind the speedometer. Find a small black switch and switch it. I forgot what side it was on. It should take you less than 2 min. No tools required, well maybe to switch the switch, it is recessed somewhat.
PHP: 7.4.33 Page Time: 1.103s Queries: 16 (0.004s) Memory: 0.6395 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-05-30 06:00:01 UTC
