Crush sleeve eliminator #791937 02/23/07 03:34 AM
Z
zachtheterrible Offline OP
I'm gonna be regearing pretty soon here, gonna go to 4.88's with 35's <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
I was reading something about using a crush sleeve eliminator, is this worth it?
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: Crush sleeve eliminator [Re: zachtheterrible] #791938 02/23/07 04:02 AM
CJM Offline
In my opinion yes ..
when I did my ARB's .. I used the OE spacer out of the 79-80 toys , and the shims .. 1 time set up .
83 Trekker SR5
NEW Trekker forum
Re: Crush sleeve eliminator [Re: zachtheterrible] #791939 02/23/07 05:27 AM
OOP'S Offline
Yep!!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Crush sleeve eliminator <<get it.>> [Re: zachtheterrible] #791940 02/23/07 05:57 AM
L
leiniesred Offline
All the Toyota diffs I built have a solid spacer. no crush sleeves. Just do it. Peace.
Re: Crush sleeve eliminator <<get it.>> [Re: leiniesred] #791941 02/23/07 07:44 AM
P
pineymudder Offline
were can i get these at? i had one and used it now i am setting up another pair of 4.88 and am about to set up a pair of 5.29. i just bought a regular crush sleeve from the dealer for $14. there is no way i could get a crush sleeve eliminator from them cause whenever i get parts from them they will not look anything up without a vin#. they suck (both local dealers) i couldnt get them to look up the starter rebuild kit... they said it didn't exist. i got the part # and finaly they ordered it for me. its like pulling teeth with them.
stuck in the mud somwere in the swamps of jersey
Re: Crush sleeve eliminator <<get it.>> [Re: pineymudder] #791942 02/23/07 07:48 AM
P
pineymudder Offline
never mind i found the # in the part # thread... who would have thought to look there?
# 41231-39010
Re: Crush sleeve eliminator <<get it.>> [Re: pineymudder] #791943 02/23/07 01:57 PM
maxxis85 Offline
Okay The spacer is used with shims correct? Use appropriate shims to get correct pinion bearing preaload? Seems better to have this if you have to repair the diffs and beat trying to crush the sleeve. Any input would be appreciated.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: Crush sleeve eliminator <<get it.>> [Re: maxxis85] #791944 02/23/07 03:29 PM
Red_Chili Offline
Toyota Section Staffer
You nailed it.
Pinion seal replacement becomes painless as well.
I don't know about strength claims, but they make sense. Sooooo much easier to set up gears.
P.S. get a good inchpound torque wrench, if you don't already have one. And http://www.gearinstalls.com (our own ZUK) is very helpful.
-Bill
Re: Crush sleeve eliminator <<get it.>> [Re: leiniesred] #791945 02/23/07 03:30 PM
Red_Chili Offline
Is this Rudeboy from Rising Sun?
-Bill
PHP: 7.4.33 Page Time: 3.693s Queries: 15 (0.003s) Memory: 0.6259 MB (Peak: 0.7286 MB) Data Comp: Off Server Time: 2026-06-22 14:18:42 UTC
