Page 3 of 7 1 2 3 4 5 6 7
Re: sas prices [Re: 87Toy4x4] #792611 02/27/07 03:49 AM
Scerb Offline
but, i've looked into doing a sas myself, and the minimum you're going to spend is about $2,500.
Where'd you get that number?? The trail-gear kit is $1100. I got my axle for $200. Can make a square driveshaft for <100 or get a custom one for about ~300. Thats ~$1400-$1600 with more than you need. Of course that price goes up substantially if you can't weld.
-Scerb
Re: sas prices [Re: Scerb] #792612 02/27/07 04:05 AM
eightyeight Offline
my SAS cost me just under 2 grand all together. including a different pitman arm, bumpstops and a few other small changes to the way the kit was intended. $1500 is do-able IF you can weld it yourself.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: sas prices [Re: Scerb] #792613 02/27/07 04:19 AM
87Toy4x4 Offline
one of the main reason's for the price differences is the addition of the rear lift, which i would of had to buy. but going by marlin's prices i figured,
$1549 for the kit, including shipping
$699 for the rear lift, including shipping
~$250 for the driveshaft
~$250 for the axle-
that's already at $2748. plus the axle will probably need to be rebuilt which is ~$150 including wheel bearings. of course you could do it for a little cheaper w/ blocks and etc. for the rear, but i sure wouldn't if i'm dropping that kind of money.
w/ trail gear's kit, you save about $350 but your still at ~$2500 if you rebuild the front axle.
Re: sas prices [Re: jonny_fookou] #792614 02/27/07 04:39 AM
Robinhood150 Offline
Yup, don't forget the rear, that's another $700 for the TG rear leaf conversion or All pro links. Depending on how your DS angles you might need a CV rear DS.
I've got about $4000 into mine, but that includes a front high pinion elocker.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: sas prices [Re: Robinhood150] #792615 02/27/07 04:42 AM
bkg Offline
Yup, don't forget the rear, that's another $600 for the TG rear leaf conversion or All pro links. Depending on how your DS angles you might need a CV rear DS.
Pretty funny how people forget about the rear, driveshafts, gears and tires when talking about doing an SAS. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Brian K. Gallus
Re: sas prices [Re: bkg] #792616 02/27/07 05:03 AM
P
pineymudder Offline
the tg kit comes with front axle renew kit w/ bearings. i also have 4.88 gears set up in 2 8" houseings. already have some 35's. i have had a miller 250x for years and know how to use it well. i also have 6" springs (all 4) i got with my front axle and the drive shafts. so other than that all i need is the kit. i think??? i was also thinking, screw the kit and just get the shackle mount jig and tubes, double stack the passenger side knuckle and make my own crossover steering and front hanger. i dont need hy-steer, aint no rocks in jersey. anybody ever done it without the kit?
stuck in the mud somwere in the swamps of jersey
Re: sas prices [Re: pineymudder] #792617 02/27/07 08:25 AM
jonny_fookou Offline OP
after the trail-gear ifs eliminater and the rear likt kit what else do i need purchase or fab to complete the sas and the rear lift like gears, driveshaft aside from tires
and another thing after all is said and done i will have the sas with the 5inch springs and a 3inch body lift what is the largest sive tires do yall think i will be able to run
--jonathan
Re: sas prices [Re: jonny_fookou] #792618 02/27/07 03:29 PM
OOP'S Offline
I am running 4" springs, 1" BL cut fenders and the front wheels wells tubbed. I am running 36 x 13.50 IROKS with no rub.
You do not want/need a 3" BL your CG is going to be too high and it will be very tipsy on the trails. Moreover, a BL that high is hard on the body mounts and they will eventually fair. Why, a thing called leverage.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: sas prices [Re: OOP'S] #792619 02/27/07 09:12 PM
im not worried about the tires its that i will be performing the 3.4 swap around the same time i do the sas or will i even need to do the 2inch lift required to do the 3.4 swap and i am not cuttin a hole in my hood to get covered up by some retarded lookin hood scoop
--jonathan
Re: sas prices [Re: jonny_fookou] #792620 02/28/07 04:14 AM
anybody there????
--jonathan
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6414 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-10-22 14:03:49 UTC
