Where can i get a 22re clutch and flywheel? #792717 02/26/07 06:57 AM
ToYPU Offline OP
Yes, i got another yota and im real happy about it! The trucks an 87 owned by my father then my grandfather. Now its mine, needs a clutch and possibly a flywheel as well. The truck has 45k on it but its rusted to hell! Practically has no bed. any way the problem is as soon as you begin to let the clutch out the entire truck vibrates like hell untill the clutch is all the way out. Once the clutch is locked up its fine... You can only feel it when you start from a stop. So im assuming it needs a clutch and flywheel. I am looking for a cheap setup, stock is fine. Where will i get the best deal?
Thanks
Kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
Re: Where can i get a 22re clutch and flywheel? [Re: ToYPU] #792718 02/26/07 08:39 AM
kewlynx Offline
Probably NAPA with a military or AAA discount if doing it on the cheap. I've also gotten flywheels out of junkyards and have had them touched up and the runout checked before using them.
Might also rule out the slave cylinder
http://www.4x4wire.com/toyota/maintenance/clutchmaintenance/
**ubi apis- ibi salus**
Re: Where can i get a 22re clutch and flywheel? [Re: kewlynx] #792719 02/26/07 02:23 PM
babyhuey Offline
I got my flywheel from advance auto parts for $50.Was cheaper than having it surfaced.I will never use another HD clutch because my LCE kit has a little bit of slip,so next time I will get clutch from advance too or maybe stock.
Re: Where can i get a 22re clutch and flywheel? [Re: kewlynx] #792720 02/26/07 04:23 PM
ChrisH Offline
napa does AAA discounts????
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: Where can i get a 22re clutch and flywheel? [Re: ChrisH] #792721 02/26/07 05:15 PM
ToYPU Offline OP
thanks for the replies. i will price them at the local autozone and advance auto and see whos cheaper. Theres a clutch kit on ebay for $135 its stock. any one ever use an ebay kit?
Thanks
Kevin
* New mods *
  • minor body work
Re: Where can i get a 22re clutch and flywheel? [Re: ToYPU] #792722 02/26/07 05:55 PM
Staceman Offline
Good quality for stock replacement clutch kits from JTOutfitters. They do ebay too. That's what I got <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Where can i get a 22re clutch and flywheel? [Re: Staceman] #792723 02/27/07 01:45 AM
mrstang01 Offline
NAPA does honor AAA.
85 4Runner on 36's, Almost there!!!
85 4Runner on 35's, Build also in progress
89 4Runner on 31's, IFS still intact
Re: Where can i get a 22re clutch and flywheel? [Re: mrstang01] #792724 02/27/07 05:52 AM
yotaman7 Offline
I know you said you were lookin for somethin cheap but just wanted to say that I just installed a clutch/pressure plate/flywheel that I got from Marlin Crawler for a 22re. It was the conventional clutch with a 1200lb pressure plate. I really like it. Cost was 275 total plus shipping, which took over a month by the way! So if you decide to spend more money try a marlin clutch if you don't mind waitin.
Click here for the link to Marlin's clutchs.
Rob
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: Where can i get a 22re clutch and flywheel? [Re: yotaman7] #792725 02/27/07 06:04 AM
Happy Birthday 87Toy4x4 Offline
i'm also recommending jtoutfitters.com. i've ordered two oem clutch kits from them and they arrived at my house in 2 days. they are located in nc and im in va so that had something to do w/ it but still lol. a lot of companies take a while to ship stuff out to you.
Re: Where can i get a 22re clutch and flywheel? [Re: 87Toy4x4] #792726 02/27/07 06:25 AM
dcg9381 Offline
Check to see if you can have your FW surfaced... Then pursue an alternative.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6390 MB (Peak: 0.7457 MB) Data Comp: Off Server Time: 2026-05-29 19:57:42 UTC
