Re: dual cases [Re: missouriman] #793020 02/27/07 06:19 AM
OOP'S Offline
oh, and I am running dual stock cases in mine.
the only problem that I have is that the shop I had put them together didn't use marlin's adaptor, even though that is what I bought. I just found out about 2 months ago it is an AA adaptor. that is why it growels.
The early Marlin adapters were made by AA, I think it may even have AA cast in to it. Cannot remember it has been so long since I have had mine out and I am old and forget things nowdays.
If you know for sure they did a switch on you they would sure hear about it from me!!!!!! I know mine is Marlin, Marlin delivered it to me!!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: dual cases [Re: OOP'S] #793021 02/27/07 06:34 AM
87Toy4x4 Offline
I think marlin changed their adapters recently b/c this pic was off of their site.
Re: dual cases [Re: OOP'S] #793022 02/27/07 02:02 PM
missouriman Offline
it has been seveal years now, it groweled from the start. I thought it was the transmission. but did a clutch and changed it out. same sound. looking at marlins site and the thin bearing is where I figured it out. or as you said it might have been marlin's early adaptor. so I can't really say much. after blowing a rear end because the bolts were not tight I don't go there exept for parts. he had a real hard time with help for a while.
Re: dual cases [Re: missouriman] #793023 02/27/07 08:12 PM
Red_Chili Offline
Toyota Section Staffer
You do not need to upgrade the splines in the rear case. The 'Total Spline' system is quite strong even in 21 spline.
In fact, I run the 21 spline in the rear case even though the Chili sports a 3.4. You will never hear them claim that is recommended, but... they have never had a failure in the TS system to date (last I checked).
-Bill
Re: dual cases [Re: 87Toy4x4] #793024 02/27/07 08:34 PM
DirtyHarry Offline
Toyota Moderator
That photograph is off the input shaft for the gears, it has nothing to do with which dual case adapter you use.
I see a lot of axle failures on the trail but rarely see any transfer case related failures in Toyotas regardless of which adapter or gears people are running. I have seen output shafts break in a few instances but these were generally in vehicles with 40" tires and guys that were dropping the hammer to try and climb something.
Re: dual cases [Re: DirtyHarry] #793025 02/28/07 05:01 PM
Red_Chili Offline
I have seen posts of worn/failed couplers in the older design...
-Bill
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6188 MB (Peak: 0.7073 MB) Data Comp: Off Server Time: 2026-06-07 05:01:08 UTC
