dual cases #793010 02/27/07 01:27 AM
eightyeight Offline OP
so i have decided to go with dual cases in the near future.
this is on a W56 tranny. will be using stock case gears and 21 spline setup.
plan on buying the adaptor kit and crossmember from marlin. what else do i need (other than driveshaft mods)?
i have a transfer case off a G52 trans, this is the same case as a W56 correct?
anything else i should look into?
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: dual cases [Re: eightyeight] #793011 02/27/07 01:43 AM
Elbow_Greese Offline
the G52 trans will most likely be a forward shift case.
Correct me if I'm wrong, I think you'll need to get the parts to make it a top shift too.
I think that's it though.
You're going to do stock gears in each case then?
If/when I do that I'd like to do 4.7 gears in the rear case, stock in front. Just my thoughts.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: dual cases [Re: Elbow_Greese] #793012 02/27/07 02:53 AM
87Toy4x4 Offline
i have a g52 and it's forward shift. i'm pretty sure you need the top shift case from a 22re tranny. or at least thats what marlin told me when i talked to him about doing dual cases on my truck.
Re: dual cases [Re: 87Toy4x4] #793013 02/27/07 03:05 AM
alright, good to know. i can get a tcase off a W56 trans.
im going with stock gears for now for money reasons. sure 4.7's would be nice, but itll end up costing twice as much. i can always regear later anyways. and it'll be a hellova lot better than a single stock case.
-matt
Re: dual cases [Re: eightyeight] #793014 02/27/07 03:11 AM
87Toy4x4 Offline
plus when you run 4.7's you have to upgrade the spline on your transfer case which is $$.
Re: dual cases [Re: eightyeight] #793015 02/27/07 03:12 AM
That's the main reason I haven't done duals yet.
I already have a second case, but the money is no where near there. I'll continue having fun with the way it is for a while though!
94 2wd v6 extracab
Re: dual cases [Re: 87Toy4x4] #793016 02/27/07 04:15 AM
missouriman Offline
why would you have to upgrade the spines?
the 4.7 set 21 spline is beefy... I just put a set in my wifes truck. single case.
with the forward shift transmission and a top shift case you can make the single case a twin stick easy.. My wife loves hers.
Re: dual cases [Re: missouriman] #793017 02/27/07 04:33 AM
87Toy4x4 Offline
Last year I called up marlin b/c i was debating on doing dual cases, or getting 4.7 crawler gears, but in the end some other things came up and i wasn't able to get either lol. Anyway, he told me i would have to upgrade the input spline on my transfer case if i was to get crawler gears instead of dual cases, which was extra. But it looks like on the site that it's included in the kit, i just took his word for it.
Re: dual cases [Re: 87Toy4x4] #793018 02/27/07 04:45 AM
bkg Offline
Marlin recommends running 23 spline in the rear case whenever possible. Many, MANY people run 21 splines, but they have a higher instance of failure.
Brian K. Gallus
Re: dual cases [Re: 87Toy4x4] #793019 02/27/07 04:57 AM
missouriman Offline
oh, and I am running dual stock cases in mine.
the only problem that I have is that the shop I had put them together didn't use marlin's adaptor, even though that is what I bought. I just found out about 2 months ago it is an AA adaptor. that is why it growels.
PHP: 7.4.33 Page Time: 2.035s Queries: 16 (0.004s) Memory: 0.6399 MB (Peak: 0.7602 MB) Data Comp: Off Server Time: 2026-06-17 00:39:54 UTC
