Transmission check/fill #793075 02/27/07 02:54 AM
Kingrya Offline OP
I've had this truck all of about 3 days now, and the other day i noticed that under my hood(3.2L) there is no (auto)transmission dip stick, or fill tube... how are you suposed to change your fluids? the manual says to take it to a dealer but that seems a little rediculous. any info is appreciated and i hope this isnt a dumb question
1996 Trooper SE 4x4, 265/75R16 ProComp All Terrains
Re: Transmission check/fill [Re: Kingrya] #793076 02/27/07 03:28 AM
Richard Saylor Offline
There's a fill/drain plug similar to a manual transmission. Do a search on here and you'll get more specifics. But essentially you have to fill it with fluid until it starts dribbling out the fill hole while the engine is running.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Transmission check/fill [Re: Kingrya] #793077 02/27/07 05:06 AM
BigSwede Offline
Let Jiffy Lube do it, unless you enjoy laying under the vehicle with the engine running.
Serenity now!
Re: Transmission check/fill [Re: Kingrya] #793078 02/27/07 05:56 AM
BigHornE Offline
I've read several comments about the GM-sourced auto box in our post-91 Troopers not having dipsticks, but mine does.
I checked the option codes and it says there's a 4L30E down there.
Did some have 'em and some not?
BH
Re: Transmission check/fill [Re: BigHornE] #793079 02/27/07 06:35 AM
josh93rodeo Offline
My 93 Rodeo has a dipstick, guess I'm just lucky <img src="/forums/images/graemlins/smile.gif" alt="" />
93 Rodeo 4x4 3.2 auto
Tinted Windows
SuperWinch hubs
Full Kenwood audio system
Indy4x 3" lift, SS brake lines, HD tie-rods, DOR diff drops & UB skidders, Procomp ES3000's
Re: Transmission check/fill [Re: BigSwede] #793080 02/27/07 06:49 AM
You know I respect ya a lot Steve, but that comment just made me cringe. <img src="/forums/images/graemlins/scared.gif" alt="" />
84 Honda XL185S
Re: Transmission check/fill [Re: Richard Saylor] #793081 02/27/07 03:26 PM
BigSwede Offline
Not sure what you mean, I was quite serious. To reach the fill hole you have to wriggle underneath the vehicle. The vehicle has to be level, so you can't jack it higher to make room...and the level has to be checked with the engine running and warmed up. So you have to worry about hot exhaust, noise, etc. too. Not fun IMHO.
Serenity now!
Re: Transmission check/fill [Re: BigSwede] #793082 02/27/07 04:36 PM
I understood your intent behind it. What made me cringe was the jiffy lube part of it. I just don't trust any place like that. That's all.
84 Honda XL185S
Re: Transmission check/fill [Re: Richard Saylor] #793083 02/27/07 05:09 PM
BigSwede Offline
Ah, well believe me, "letting" Jiffy Lube do it includes me standing there watching them do it so I know they did it properly...
Serenity now!
Re: Transmission check/fill [Re: BigSwede] #793084 02/27/07 05:13 PM
Believe me, I'm the same way. Still don't trust them though. <img src="/forums/images/graemlins/scared.gif" alt="" />
84 Honda XL185S
PHP: 7.4.33 Page Time: 1.931s Queries: 16 (0.004s) Memory: 0.6441 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-06-07 01:18:33 UTC
