Parking brake light wont turn off! #793199 02/27/07 02:59 PM
E
EDS2000tacoma Offline OP
hey guys,
when i take my parking brake off the light will stay on and some times it will come on and off while i am driving. anybody have any sugestions.
Thanks for the help,
Eric S.
Eric S.
2000 Tacoma
-6in of lift,33x12.50 truxx's M/T's
Re: Parking brake light wont turn off! [Re: EDS2000tacoma] #793200 02/27/07 05:33 PM
Jake97T Offline
low brake fluid sensor in your master cylinder reservoir, check your front pads for wear, if they're good put a little more in the reservoir, should go away.
Re: Parking brake light wont turn off! [Re: Jake97T] #793201 02/27/07 05:39 PM
DentedTacoma Offline
All my stuff checks out and I get the same thing. I hear of a lot of people that get this issue. Mine has got to be the e-brake cable doing something that keeps the sensor on even though it is disengaged. If everything checks out alright and the e-brake is not engaged while driving then it isn't too much of a concern in my opinion.
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: Parking brake light wont turn off! [Re: EDS2000tacoma] #793202 02/27/07 08:42 PM
azrain Offline
The sensor in the reservoir cap can also go bad.
Re: Parking brake light wont turn off! [Re: azrain] #793203 02/28/07 03:12 AM
gcinque Offline
I have the same problem on my 03 Xtra cab, 4cyl, 5Spd with 49k miles. When I release the parking brake the light doesn't turn off. Sometimes I twist the Parking Brake handle around and push it in at the same time and the light sometimes stays off.
I'll check the brake pads and fluid just in case.
gcinque
03 Tacoma Xtra cab 4cyl 5spd
89 4Runner/Jasper reman 22RE/Auto SOLD
98 Tacoma Xtra cab 4cyl Auto SOLD
Re: Parking brake light wont turn off! [Re: gcinque] #793204 02/28/07 05:03 AM
lethe Offline
i dont know if tacos are the same but on my mini i just disconnected a little switch that the end of the ebrake handle rod thing would push in on the firewall to turn that light off?
87' ext cab toy
Re: Parking brake light wont turn off! [Re: lethe] #793205 02/28/07 02:58 PM
E
thanks guys i have got some stuff to try, ill let you guys know what works.
Eric S.
2000 Tacoma
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6160 MB (Peak: 0.6896 MB) Data Comp: Off Server Time: 2026-06-07 13:34:16 UTC
