gas tank carniage #793483 02/28/07 02:16 PM
A
anubis Offline OP
I have a second gen rodeoport and after alst wheeling trip realized that on my fill ups I am coming in 2 gallons short. THe tank has had a large impression placed on it as well. Im thinking that it dispaced and is keeping gas from getting to the pickup line as well.
ANyone else run into this. Im thinking that it is futile to try to fix so I guess I will be stoping for more gas <img src="/forums/images/graemlins/kewl.gif" alt="" />
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: gas tank carniage [Re: anubis] #793484 02/28/07 02:38 PM
Bigpoppax2 Offline
You can fix this pretty easy. I had my tank down for one reason or another (I cut two holes in it on accident) <img src="/forums/images/graemlins/shiner.gif" alt="" />, so I cleaned it out good with water and filled it completely up with water then welded the bad places.
Afterward I used compressed air to test it. That's some pretty thin metal, my tank popped out on top and bottom. <img src="/forums/images/graemlins/notooth.gif" alt="" /> It took some doing with a rubber mallet to get it back into shape.
I'm going to say it'd be harder to get the dent out of the skid plate then to fix the tank.
The tank and skidplate do come apart so that's not an issue.
Hey now that you are going to drop the tank down, and seeing as you do have a 3" body lift.......
Sounds like the perfect time for a 3" gas tank lift. <img src="/forums/images/graemlins/evil.gif" alt="" />
Joe
Re: gas tank carniage [Re: Bigpoppax2] #793485 03/02/07 02:46 AM
Iluvmud Offline
My gas tank has a rather large dent in it and is a few gallons short too. I am not worreid about it...I wear at as a battle scare just like all the other dents, scrapes, and such. Infact, if you watch the most recent uwharrie video floating around you can see when I hit, the back end jumps a few inches in the air and my licens plate goes from stright up and down to a 45 degree angle instantly. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" />
8 inches of lift, 33s, custom bumpers and rockbars, powertrax, T-maxx 9000, lots o lights, and some bass in the trunk
Lifted, locked, and ready to rock!!! <img src="/forums/images/graemlins/evil.gif" alt="" />
[url=http://www.cardomain.com/memberpage/743285][/url]
Re: gas tank carniage [Re: Iluvmud] #793486 03/02/07 10:53 AM
A
anubis Offline OP
Body lift may be coming out in may. With teh axle swap trying to get started <img src="/forums/images/graemlins/lol.gif" alt="" /> It has been sugested that the amount of lift to it with new shoes and all may cause some serious roll issues.
Id liek to keep the scares but also I need to be able to amke long trips without worry <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: gas tank carniage [Re: anubis] #793487 03/02/07 03:02 PM
TrailMystic Offline
Hey Bryan,
Did you do that at Crozet? I warned you about that place <img src="/forums/images/graemlins/shiner.gif" alt="" /> Let me know next time you go and I'll join you <img src="/forums/images/graemlins/lol.gif" alt="" />
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: gas tank carniage [Re: TrailMystic] #793488 03/02/07 08:52 PM
A
anubis Offline OP
Pete heading up there next saturday. Open wheeling day. Drop me a pm if you are interested and I will get you details.
Other note i did take a dent to the pax side door. it is permanent and shall live on.
Re: gas tank carniage [Re: anubis] #793489 03/03/07 04:01 AM
Iluvmud Offline
How far is that from Richmond? On a good day i can be in richmond in about 2 hours so if it is not too far from there maybe i can make it.
Re: gas tank carniage [Re: Iluvmud] #793490 03/03/07 05:25 AM
mlclark Offline
Isuzu Moderator
Keep the off-topic and individual discussions via PM, please.
michael
Re: gas tank carniage [Re: mlclark] #793491 03/03/07 07:17 PM
Jeff Mason Offline
If I remember correctly, Gen2 gas tanks are polymer, not metal(*). If you can get the skid off and can remove the dents from it, you might be able to get the tank to pop back out to normal.
(*) - at least a 2Gen amigo tank is polymer. I am assuming that the Rodeo is too.
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Re: gas tank carniage [Re: Jeff Mason] #793492 03/04/07 09:13 PM
Mr. Mojo Offline
If I remember correctly, Gen2 gas tanks are polymer, not metal (*).
How do you weld polymer ? <img src="/forums/images/graemlins/pfft.gif" alt="" />
98 Rodeo
00 4Runner
--I swear its just over the next pass !!--
--"Courage is something you can't be afraid to have." - Frank Burns
PHP: 7.4.33 Page Time: 4.666s Queries: 16 (0.005s) Memory: 0.6392 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-06-17 00:45:47 UTC
