Anti Freeze Leak Source #793556 02/28/07 08:57 PM
mtboulder Offline OP
I have a '98 Trooper with 98K miles on it. I have anti freeze leaking from the front drivers side of the engine that is making its way down onto the steering linkage. I cannot see the source of the leak but it appears to be somewhere between the power steering pump and the engine block.
I replaced the water pump and timing belt a few months ago and the leak does not seem to be coming from aroud the fly wheel area so I don't think it's the water pump.
The two large radiator hoses and where they attache to the block aren't leaking either.
Any other possibilities? It looks like there may be some smaller water hoses that connect to the block uder the intake manifold?
Re: Anti Freeze Leak Source [Re: mtboulder] #793557 02/28/07 09:40 PM
Bigpoppax2 Offline
There are two heater hoses (hard lines and the thermostat) under the intake. There are also some coolant lines going to the throttle body.
Joe
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.014s) Memory: 0.5870 MB (Peak: 0.6354 MB) Data Comp: Off Server Time: 2026-11-13 06:30:39 UTC
