sas on my 94 passport #793647 03/01/07 03:13 AM
hello, im new to the isuzu world and wondering if anyone can point me in the direction of some good blogs specifically regarding rodeo/passport sas. thanks. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: sas on my 94 passport #793648 03/01/07 03:16 AM
strawmyers Offline
Isuzu Moderator
I'm not much of a "blog" person... but I can tell you that if you use the search function in the Isuzu Forums with keyword +SAS, you'll have enough reading to keep you busy for many moons. Welcome aboard. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Sean Strawmyer
Re: sas on my 94 passport [Re: strawmyers] #793649 03/01/07 03:19 AM
Starchild Offline
This will get you started
SAS Archive
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: sas on my 94 passport [Re: Starchild] #793650 03/01/07 03:30 AM
I've enjoyed the search function on this forum, I was wondering if there was an isuzu off road forum, similar to the ttora for tacomas? Or just other forums i can find more info on isuzus, seems a bit harder to find than toyota info.
Re: sas on my 94 passport #793651 03/01/07 03:40 AM
langforg Offline
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
Re: sas on my 94 passport [Re: langforg] #793652 03/01/07 03:53 AM
how are the frames on them, are you guys having to plate around the steering boxes? Is the box far enough forward on the frame to prevent interference with a hi steer setup?
the spring choices seem funny, 4044's to keep it low?? and rear springs out of a 4x4 suburban??
Re: sas on my 94 passport #793653 03/01/07 07:32 AM
Jeff Mason Offline
go nose around planetbantz DOT com Mike did a SAS a couple of years ago on his Rodeo and has done some impressive weheeling with it since then.
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Re: sas on my 94 passport #793654 03/01/07 08:15 AM
94rodeo Offline
I have been running my stock box with no problems for about 4 years almost 5 now. I don't have issues with my steering, but I don't have the high steer either. I am still running the stock springs in the rear, but would recommend something longer to get more droop out of when the suspension cycles. I did coils up front and they work great with respect to finding the right stiffness and height, very easy to swap out.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6140 MB (Peak: 0.6956 MB) Data Comp: Off Server Time: 2026-06-07 07:11:17 UTC
