Front end noise? #793659 03/01/07 05:35 AM
E
eastcoast Offline OP
22re w/ 4k on the rebuild...i have a rattle coming from the front of the engine that sounds JUST like a timing chain rattle. all new EB parts 268 cam w/ OS valves, LC adj. cam gear, lash set to .007/.009 cold, as per eb recommendations. pulled the valve cover, some scuff marks on the baffle from the rockers, so that was a lil tight, still didnt help the noise. TC guides and tensioner look fine, no slack in the chain. oil pressure is good, by the stock gauge anyways, and the sound mostly goes away when its not idling. now ill admit, im stumped. any thoughts or ideas would be greatly appreciated. thanks in advance.
'94 X-Cab, EB inside and a few fabbed parts. My wife: "How about you stay on the road?" Me: "I drive a Toyota truck, the road is OPTIONAL!"
Re: Front end noise? [Re: eastcoast] #793660 03/01/07 08:16 AM
dcg9381 Offline
pull the valve cover, look down the front of the motor, drivers side. There are two bolts that hold on the drivers side guide.
Do they show signs of wear or damange from the chain?
22REturbo.net
1988 4Runner
Re: Front end noise? [Re: dcg9381] #793661 03/01/07 10:04 PM
E
the top bolt looks fine, bottom bolt is about 1/3 worn through on the side next to the chain.
tensioner failure?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5897 MB (Peak: 0.6430 MB) Data Comp: Off Server Time: 2026-05-30 17:08:33 UTC
