Re: 3.4 liter valve adjustments [Re: Scott McCrea] #793687 03/14/07 11:59 AM
E
eppoh Offline
Since there is already one dumbie on this thread, I'll ask a dumb question, what symptoms would tell you that it's time for a valve adjustment?
(ticky, ticky, ticky, tick, tick, tickitty tick....dumby #3 here ) Yeah that was dumb
to answer your question, you will now\t hear anything when valves need adjusting. As the engine gets older, either the valves begind to recess a litte ( no noise, but exhaust valves burn and leak) or they become a little loose- hence the ticky ticky when the engine is cold. Don't worry about it so long as your compressions are good and your performance isn't suffering. Most never get adusted.
Re: 3.4 liter valve adjustments [Re: eppoh] #793688 03/14/07 05:11 PM
Jake97T Offline
Ive only seen a few 3.4L engines that needed valve adjustments, they were noisy cold as well as hot.
Re: 3.4 liter valve adjustments [Re: Jake97T] #793689 03/15/07 01:50 PM
hank1968 Offline OP
Well mine are quiet at startup then once warm then the ticky tic tic starts also the oil pressure on the gauge is almost on the L.Think its time for an oil pump.
Re: 3.4 liter valve adjustments [Re: hank1968] #793690 03/17/07 09:38 AM
E
eleet Offline
That is pretty normal idle oil pressure on a warm engine.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6076 MB (Peak: 0.6631 MB) Data Comp: Off Server Time: 2026-06-07 06:51:34 UTC
