Timing Belt
#793702
03/01/07 04:16 PM
Anyone got a part number for the Timing belt set for a 4D56? I think it's time to get that done.
Kelvin 91 Pajero Exceed - Controls mounted curb-side for convenience 82 Mercedes 300SD
Re: Timing Belt
[Re: Brewmaster]
#793703
03/01/07 05:43 PM
original Mitsu part # MD134377 Dayco # 95092 Balance belt cross # Dayco 95091
Re: Timing Belt
[Re: Brewmaster]
#793704
03/02/07 12:56 AM
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
Re: Timing Belt
[Re: 87Montero]
#793705
03/02/07 02:54 AM
yea. I would not go with dayco timing belts though. I have seem them break before the mileage interval. OEM mitsubishi and Contitech are VERY good belts. thats part number MD134377 is only for the belt. you will need new pulleys and the hydraulic tensioner aswell. and might as well do the cam/front crank/balance shaft seals at the same time. and also good time to change the water pump. it gets expensive but theres no better of a time to do it. I want to change my timing belt right away too.
I'm pretty sure you can source the timing belt stuff for an old d-50 4D55 diesel. water pump im not sure though. phil can probably verify this if he feels like spending countless hours on CAPS japan. haha
Re: Timing Belt
[Re: torquemonster]
#793706
03/02/07 03:02 AM
I got mine done and the oem belt was made by Gates
Re: Timing Belt
[Re: jasen]
#793707
03/02/07 03:38 AM
I did the timing belt, tensioner, balance shaft belt, tensioner and water pump in a few hours. The 4D55T is a breeze to work on compared to the 3.0 V6! The only trouble I had was that it took me two tries to seal up the thermostat housing without leaking.
I don't know about the 4D56 but the 4D55T timing belt interval is only 50k miles so make sure you don't let it go too long! <img src="/forums/images/graemlins/scared.gif" alt="" /> (I believe it is an interference engine)
Pmontero
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6069 MB (Peak: 0.6773 MB) Data Comp: Off Server Time: 2026-05-30 11:54:56 UTCValid HTML 5 and Valid CSS
