Runs rough until reachs normal temp. #793930 03/02/07 02:50 PM
RalkClimber Offline OP
Title says it all..
'97 Jeep Wrangler 2.5L 105k miles.
EDIT: LOL just added the info to my Sig smile
Recent Replacements: Cam Shaft, Lifters, Push Rods, Distributor, Dist. Cap/button, Plugs, Oil Pump, Oil Sending Unit, Timing Chain/sprokets, and all associated gaskets. <img src="/forums/images/graemlins/scared.gif" alt="" />
Ralk
'97 Jeep Wrangler 2.5L 105k Miles
Re: Runs rough until reachs normal temp. [Re: RalkClimber] #793931 03/02/07 03:43 PM
BigJim Offline
I never worry about the warm-up time... What it runs like when 200* is all that matters. If it bothered me I'd keep her warm all night! <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Runs rough until reachs normal temp. [Re: RalkClimber] #793932 03/02/07 03:45 PM
DBL_DTY97TJ Offline
Idle control motor? Not a mech., but I'll make a guess on that one.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Runs rough until reachs normal temp. [Re: DBL_DTY97TJ] #793933 03/04/07 02:09 AM
9
93yj Offline
I'd wager that it's your coolant temperature sensor...very likely. There are 2....one in the head that you guage reads off of and one that screws directly into your thermostat housing. The "main" one is in the thermostat housing. If the IAC was bad it's run bad at idle ALL of the time (as far as I am aware of).
Re: Runs rough until reachs normal temp. [Re: 93yj] #793934 03/04/07 04:09 AM
BigJim Offline
I think the one you refer to is called a temp "switch" It either sends a ground or not.
Re: Runs rough until reachs normal temp. [Re: BigJim] #793935 03/04/07 05:21 AM
playinmud Offline
93yj is correct with the IAC it will idle high all the time when not in gear, sorry i cant help you out with your problem tho hopefully someone else can
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6080 MB (Peak: 0.6775 MB) Data Comp: Off Server Time: 2026-11-12 14:22:26 UTC
