Re: stupid bolt [Re: playinmud] #793970 04/30/07 02:24 PM
bhartwell59 Offline OP
I finally got it loose.
i did take the entire sway bar off (being lazy, i really didn't want to do) and soaked the frozen bolt end with more liquid wrench and on the second try, BAM!
<img src="/forums/images/graemlins/lol.gif" alt="" />
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: stupid bolt [Re: bhartwell59] #793971 04/30/07 03:00 PM
BobRowe Offline
I just replaced the sway bar bushings, clamps, and quick disconnects on my CJ7. I would suggest that you do the same thing i did -- use all new Grade 8 hardware when you put it back together, and use Anti-Seize compound on all the threads.
Re: stupid bolt [Re: BobRowe] #793972 05/01/07 04:48 PM
the nuts came off easy enough... it was the bolt in the top end link/sway bar connection that was the bear.
what kind of anti-seize did you use? i guess that's different from the white tube pre-lube tube supplied by the bushing manufacturer.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5975 MB (Peak: 0.6506 MB) Data Comp: Off Server Time: 2026-07-15 11:40:07 UTC
