Re: stupid bolt
[Re: playinmud]
#793970
04/30/07 02:24 PM
I finally got it loose.
i did take the entire sway bar off (being lazy, i really didn't want to do) and soaked the frozen bolt end with more liquid wrench and on the second try, BAM!
<img src="/forums/images/graemlins/lol.gif" alt="" />
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: stupid bolt
[Re: bhartwell59]
#793971
04/30/07 03:00 PM
I just replaced the sway bar bushings, clamps, and quick disconnects on my CJ7. I would suggest that you do the same thing i did -- use all new Grade 8 hardware when you put it back together, and use Anti-Seize compound on all the threads.
Re: stupid bolt
[Re: BobRowe]
#793972
05/01/07 04:48 PM
the nuts came off easy enough... it was the bolt in the top end link/sway bar connection that was the bear.
what kind of anti-seize did you use? i guess that's different from the white tube pre-lube tube supplied by the bushing manufacturer.
