pinion shims + trac bar
#794141
03/03/07 07:50 PM
I just finished slipping some 4 degree shims in my rear springs. I have a CV driveshaft, and the shims canceled all the angles out to less than a degree. I'm using a magnetic carpenter level and it reads between 1 degree and zero each time I measure. I've taken multiple measurements at the pinion flange (plate clamped to it), on the driveshaft and using sockets on each cap of the rear u-joint.
By now I'm fairly well convinced that I'm closer to zero than one degree off.
General practice I understand is to leave the pinion a degree low to allow a little bit of tip on acceleration, but what about when employing a traction bar as well? Do they tend to keep the axle located well enough that I can ignore the leave it low rule?
~Adam  96 T100: D44, lockers and stuff
Re: pinion shims + trac bar
[Re: adam]
#794142
03/03/07 08:01 PM
With a traction bar, you want to keep the alignment near zero degrees (w/ a CV shaft), assuming the bar prevents any rotation of the axle. If it is not 100% rigid (like if you have poly bushings in the ends), then you could leave a little up-angle.
[Re: 4Crawler]
#794143
03/18/10 06:46 PM
Toyota Moderator
I believe that part of the reasoning to leave a little angle in the joint is so that the rollers in the bearing aren't always rubbing on the same spot. If they have some slight movement then grease can have a better chance to move around and lubricate better.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5915 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-05-28 03:36:22 UTCValid HTML 5 and Valid CSS
