Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794288 10/31/07 02:52 AM
CJM Offline OP
rear section has now been removed again .. time to start working on that .
Originally , the back half sits on a "winnabego" frame , that mounts to the Toyota frame . Bushings were toast , and not worthy of the new set-up .. got me to thinkin'
The Original mounts , I dont think were sufichant , because of all of the "leaks" I hear about , so I thought a softer compound mount would work better with the flexing , and handle a better "sway" of the back 1/2 . So I ended up purchacing some NEW "special" mounts , and some steel to make a new frame .
got it all "tacked up " under the body , so now time to weld it all up .
boxing the ends .
another "goofy" part of the Trekkers is the rear lamps .. They have these silly metal " u " brackets that hold the lamps in place .. you have to drill a hole in your lamps , and mount them to the brackets ??? dumb .....
so took the pockets from the 79-83 beds I build , and glassed them into the Trekker
Very rough right now .. but at least they will be easy to install , and RE & RE .
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794289 10/31/07 02:53 AM
CJM Offline OP
and some pics from the owner ..
painted/finished in Line-X
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794290 11/01/07 12:35 AM
CJM Offline OP
so , almost got er' finished up today .. frame , anyway smile
got the rear supports tacked into place , and also some front supports . Once the back 1/2 is back on the truck , I will be able to perminantly mount them to the fenders .
pulled it out again , welder it all up and got er' into primer .. shoot on some black tomorrow , and all done that part .
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794291 11/02/07 01:08 AM
CJM Offline OP
so all done the frame smile .. tail lamp pockets are also finished
I made 2 sets of fuel tank drop brackets ... not sure which one is needed yet (I suspect the 1" ) because of the body lift .
Now on to work on the sides smile ... almost done .
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794292 11/02/07 07:46 PM
CJM Offline OP
well , jeepers creepers ... somebody say something !!!!
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794293 11/02/07 08:51 PM
A
AZcoma Offline
OK, i'll chime in. Just went through the entire thread and all I can say is... Whew! I'm tired just looking at all of the work you've done. <img src="/forums/images/graemlins/kewl.gif" alt="" /> So... are you gonna Linex blue the entire project? I'm thinking when I repaint my '86 to use something similar for the rocker panels and sides from about 1/4 way to bottom to minimize rock gouges that occur whenever quarter sized rocks come flying out of the tread at highway speeds. Best of luck to you going forward!!
'86 4x4 SR5 22re 5" lift 35" BFG's and 5:29 gears.
'05 4x4 DC Tacoma TRD Sport
Re: Our Trekker/Precision conversion is just a little closer .... [Re: AZcoma] #794294 11/02/07 09:57 PM
Staceman Offline
I've been following along too Cory.
Keep 'em coming, I love seeing the progress of a unique rig coming back to life.
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794295 11/03/07 12:26 AM
G
Greg_Canada Offline
speechless bud keep posting pics!
89 4Runner
Re: Our Trekker/Precision conversion is just a little closer .... [Re: Greg_Canada] #794296 11/03/07 12:29 AM
Vanishing_Point Offline
I read every update. Keep em coming.
Re: Our Trekker/Precision conversion is just a little closer .... [Re: Vanishing_Point] #794297 11/03/07 01:42 AM
CJM Offline OP
Thanks guys ... sometimes with out replys of some sort , good or bad .. I think I'm "wastin' space"
YES .
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6513 MB (Peak: 0.7751 MB) Data Comp: Off Server Time: 2026-06-04 07:10:39 UTC
