Page 7 of 10 1 2 … 5 6 7 8 9 10
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794298 11/08/07 02:40 AM
CJM Offline OP
so done today ... the lowers anyway ...
today is the last day the tub will be upsidedown ...
also cleaned up the rear hardware , hatch shocks , lock ketch , plate .
hatch shocks seemed to be in great shape , but the hardware was rusty .. so I bead blasted all of it , and cleaned it all up to bare metal again .. zinc'd and painted ... I left the shocks as bare metal .. ran them under my wire brush , and they kind of turned out like a brushed aluminum .. I think they look awesome , so I clear coated .. and now are ready to assemble .
I am also ready to send out the hatch and cover .. I'm also going to send out the interior canopy trim plate to be line-x'd ..
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794299 11/08/07 04:05 PM
Bogo Offline
zinc'd and painted
I'm curious what method or process are you using to do the zinc coating? I see it mentioned every so often for protecting steel.
-- Bryan
Re: Our Trekker/Precision conversion is just a little closer .... [Re: Bogo] #794300 11/08/07 05:13 PM
G
GOI87 Offline
zinc'd and painted
Same here...curious how that's being done. <img src="/forums/images/graemlins/cheers.gif" alt="" />
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: Our Trekker/Precision conversion is just a little closer .... [Re: GOI87] #794301 11/09/07 03:45 AM
CJM Offline OP
it's a zinc chromate primer .. mecularically bonds to bare steel .. must be bare steel , and clean .. no rust or imperfections .. http://www.plasti-kote.com/plastiko...amp;amp;product=zincchromate&t=3
awesome stuff ..
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794302 11/24/07 01:59 AM
CJM Offline OP
gettin close .. <img src="/forums/images/graemlins/wink.gif" alt="" />
so as promiced .. some pics ..
struts I did a while ago .
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794303 11/24/07 02:01 AM
CJM Offline OP
Original the front rear cab support bar .
Original pieces removed
stripped back to steel
drilled
and re "NUT certed"
Zinc'd and DONE !
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794304 11/24/07 02:02 AM
CJM Offline OP
and as of today .. all sealed , and ready for the topper .
I Really hate to post these ! .. cuz it looks not so great ..
and with the TOPPER ..
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794305 12/01/07 02:14 AM
CJM Offline OP
so with the Topper on .. and in it's final position .. time to assemble the rest , one more time before the line-x
side windows ..
rear gate , taillamps (not included smile ) licence plate frame and light ..
also fitted the roll bar , and hatch shocks ..
ALMOST done ... smile
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794306 12/02/07 01:39 AM
CJM Offline OP
someone say something !!!! please ...
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794307 12/02/07 02:11 AM
Bogo Offline
Looks good. <img src="/forums/images/graemlins/cheers.gif" alt="" />
I've been paying attention to it as it is giving me possible ideas for micro RV project. My original thoughts on design are very close to what a Trekker is, but I want taller and an over cab extension. I'm now playing with the idea of making a steel roll cage frame and filling in the openings with insulated fiberglass panels.
Is the connection between the back and cab of the Trekker a hard interface with no give? I've been trying to figure out how to handle that area. My current idea is to have a flange where I can put a gasket seal with allot of small bolts to hold it together. There would be no real give in the joint. I'd cut a hole in the back of the cab that only leaves a narrow flange that will mate up to a flange on the front of the back. An EDPM gasket seal would be placed between the cab and back and many bolts would clamp them together.
-- Bryan
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6530 MB (Peak: 0.7778 MB) Data Comp: Off Server Time: 2026-10-29 07:53:39 UTC
