engine connections????? #795240 03/08/07 03:14 AM
G
Goose Offline OP
Puttin bakc the heads on my 2.6l, now after the heads, lower intake manif. and re installing the fuel rail, i ran in to some memory problems, on the wiring harness that goes to the injectors, distributor, trhotle position sensor, coolant temp sensor, theare a a few that i forgot, one that goes down into through lowe manifold (slong with coolant sensor) but black??? where does it go????
another one is the a litle grey guy, (looks like the one
that goes into the top of the valve cover) where does this one go????
i know it is kinda hard to picture but any help will be good
thanks
Re: engine connections????? [Re: Goose] #795241 03/08/07 12:49 PM
Bansil Offline
The extra grey connector(that looks like the one to the coil),goes under the intake and isn't used unless you have a calif. model with I think heated egr or something.
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5861 MB (Peak: 0.6343 MB) Data Comp: Off Server Time: 2026-05-26 09:33:07 UTC
