CROSS OVER STEERING #795277 03/08/07 05:43 AM
8
85YOTER Offline OP
I have just purchased a 1985 Toyota and am considering the "cross over steering" conversion. I am aware that I will need the steering kit from all pro as well as the steering box from an IFS truck. What else do I need to obtain or modify? Thanks for any help on this matter.
Re: CROSS OVER STEERING [Re: 85YOTER] #795278 03/08/07 05:53 AM
OOP'S Offline
If the kit does not come with the frame plates, you will need them. Not really sure about if the hoses you have will work or not.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: CROSS OVER STEERING [Re: OOP'S] #795279 03/08/07 03:48 PM
4Crawler Offline
Definately get or make some plates for the frame, plus sleeves for the bolt holes. The solid axle p/s hoses will fit with the IFS box, may have to work with them a little to get them to fit. Also, likely need to extend the steering shaft depending on where the box is mounted:
- http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml#RecirculatingBall
Re: CROSS OVER STEERING [Re: 85YOTER] #795280 03/08/07 05:34 PM
bkg Offline
And a 2-3" suspension lift.
Brian K. Gallus
Re: CROSS OVER STEERING [Re: bkg] #795281 03/09/07 03:16 AM
fourwd1 Offline
Yeah, you'll have some big interference problems w/o some lift.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: CROSS OVER STEERING [Re: bkg] #795282 03/09/07 03:18 AM
8
85YOTER Offline OP
My truck now doesn't have power steering so I will need to get the pump as well. The kit I was looking at does have the plates and parts to mount the box. Any kits you would reccomend.
Re: CROSS OVER STEERING [Re: 85YOTER] #795283 03/09/07 03:34 AM
missouriman Offline
fill out your profile.
then I will tell you.
Re: CROSS OVER STEERING [Re: missouriman] #795284 03/09/07 04:28 AM
8
85YOTER Offline OP
what profile?
Re: CROSS OVER STEERING [Re: 85YOTER] #795285 03/09/07 01:20 PM
missouriman Offline
yeh that one.
here ya go.
web page
there will be more pictures an maybe a write up as I do my wifes frame and bumper, cross over and springs. along with hydro.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6227 MB (Peak: 0.7093 MB) Data Comp: Off Server Time: 2026-06-10 08:52:47 UTC
