Re: A thought I'm Toying with...... 84 Runner [Re: Andy87] #795353 03/09/07 04:44 PM
bkg Offline
Swap bodies.
BUT...
As part of that, I would also highly recommend that you clean and paint (rust-proof) the frame, prep the 87 body well and undercoat/POR-15/spray-line the underbody, etc.
Brian K. Gallus
Re: A thought I'm Toying with...... 84 Runner [Re: trcdrunner] #795354 03/10/07 06:30 AM
W
whitetoy Offline
Swapping in a new body is the thing to do, especially where you live.
With the donor having an auto, you may have to do a lot of drilling and cutting. For example, you need a place for the clutch master to mount, unless all of the bodies are pre-drilled the same. Shifter area might need surgery. Since the donor as fuel injection, is there still an gas tank inpection plate under the right rear seat? Are body mounts in the same location for an IFS chassis?
Rick
1984 4Runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5941 MB (Peak: 0.6423 MB) Data Comp: Off Server Time: 2026-06-09 23:15:28 UTC
